Re: Show me your Cuda rear tire pics & sizes
[Re: nz383man]
#1103569
10/29/11 10:38 AM
10/29/11 10:38 AM
Posts: 761 KY
juicedcuda
KY
I ran 29x9's with that exact setup and know for sure you can get a 30 in there as well.
1970 Plymouth 'Cuda
1970 Plum Crazy "Gold Duster"
1973 Gold Duster
[Re: juicedcuda]
#1103570
10/29/11 05:17 PM
10/29/11 05:17 PM
Posts: 520 New Zealand
nz383man
New Zealand
Thanks.
Do you have any pics?
[Re: oldtimer5151]
#1103573
10/30/11 01:26 AM
10/30/11 01:26 AM
Posts: 2,042 Mooresburg, Tn
'72CudaRacer
Mooresburg, Tn
You will have to use a b body housing then fit it to the moved in spring perches. Offset the wheels and you can use a 10.5x29,5 slick.
My set up is the same. 72 cuda, B body Dana housing, 10" wheels, 11.5 x 29.5 Mickey Thompsons, SS springs moved in. To get much more tire than that, you will need to open the wheel well up.
Brian Dunnigan
[Re: Blues_Cuda]
#1103578
10/30/11 03:02 PM
10/30/11 03:02 PM
nz383man
New Zealand
295/65/15 Drag Radial on a 15x8 wheel with 4.5" backspacing and a B-body Dana 60 using offset hangars.
I wondered about using 8" or 10" wheels but I had to have the early style Keystone Klassics (which are very hard to get) & a set of NOS 15" x 10" came up so I grabbed them.
What are the advantages/disadvantages of using either of these size rims with the tire sizes mentioned?
[Re: nz383man]
#1103579
10/30/11 04:23 PM
10/30/11 04:23 PM
Posts: 3,896 St. Louis, MO
Blues_Cuda
St. Louis, MO
Honestly, I think the 8" wheels are a little narrow for the 295/65's. The sidewalls bulge quite a bit. I don't have a great picture of the sidewall bulge at my fingertips, but this one shows it a little bit.
[Re: T-bar]
#1103581
11/01/11 04:30 AM
11/01/11 04:30 AM
nz383man
New Zealand
I got 295/65r15 on a 15x10 wheel with 6 & 1/4 inch back space with the standard width diff. Springs relocated 3 inch's in and no mods to the well. Outer gaurds have been rolled. Sorry no photos at the moment but the gaurd sits down over the tyre and with the kids in the back it rubs slightly on big bumps.
Can you tell me a bit more about the 3" spring relocation & some pics would be great when you get a chance, Cheers
[Re: T-bar]
#1103584
11/02/11 05:38 AM
11/02/11 05:38 AM
nz383man
New Zealand
Can't remember the brand but basically it puts the springs on the inside of the rail the kit came with new mounts for the front and rear. Im out of town for the next week so when i can i'll take some photos and get them to you.
Thanks, I'm not in too much of a rush as my springs seem to be lost somewhere between the US & New Zealand, hopefully they will turn up soon!
[Re: nz383man]
#1103586
11/02/11 09:12 AM
11/02/11 09:12 AM
Posts: 13,360 Marion, South Carolina [><]
an8sec70cuda
295-65 M/T ET Street radial (basically a 30x10), 15x8.5" rim w/ 5" of backspacing. Stock E body width rearend, offset rear shackles. Stock ride height leaf springs. Had to roll the lip of the wheelwell up, but they still rub slightly on big bumps.
