Is this a good Alternator test ... #1103461
10/28/11 09:55 PM
10/28/11 09:55 PM
SeventySatellite Offline OP
I read this somewhere awhile back but I haven't tried it yet. Remove positive, hold it above post, if car dies then it's a bad Alternator.
Re: Is this a good Alternator test ... [Re: SeventySatellite] #1103462
10/28/11 09:58 PM
10/28/11 09:58 PM
USA
CrAlt Offline
CrAlt  Offline
USA
No thats a bad idea..
If the regulator is bad then you could fry everything in the car.
Just get a volt meter and test it the right way.
I was asked to contribute money to help solve the civil unrest in Egypt, but I suspect it's some sort of pyramid scheme.
Re: Is this a good Alternator test ... [Re: CrAlt] #1103463
10/28/11 10:09 PM
10/28/11 10:09 PM
Re: Is this a good Alternator test ... [Re: SeventySatellite] #1103464
10/28/11 10:57 PM
10/28/11 10:57 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Wrong/bad/dumb way.
RIGHT WAY
Ensure battery is fully charged.
Load test battery to make sure it's good.
Install battery in car with good clean connections.
Inspect alt., belt, mounts, wiring and regulator. Fix as needed.
Perform starting draw test.
Fix as needed.
Start car and do a charging system test with a heavy load tester.
Fix as needed.
That's why people do the disconnect thing. It's quick and easy. It does NOT check all the components and circuits like you should, and it can cause damage.
Re: Is this a good Alternator test ... [Re: RodStRace] #1103465
10/28/11 11:23 PM
10/28/11 11:23 PM
Fly Over States
P
PHJ426 Offline
PHJ426  Offline
P
Fly Over States
I don't own a load tester so I have also tested the charging by turning on all the electrical loads ie. high beams, wipers, radio, heater blower motor full speed, hazards etc all on.
Measure the voltage at idle and then I would run the rpms up slightly and measure the voltage as well.
Re: Is this a good Alternator test ... [Re: SeventySatellite] #1103466
10/29/11 01:05 AM
10/29/11 01:05 AM
Brandon, Ms
cornet684me Offline
cornet684me  Offline
Brandon, Ms
that is how Chevy guys check their Alternators,
get a meter and check it the right way
Re: Is this a good Alternator test ... [Re: cornet684me] #1103467
10/29/11 01:43 AM
10/29/11 01:43 AM
Mississippi
lahatte Offline
lahatte  Offline
Mississippi
Recommendations for a meter?
Re: Is this a good Alternator test ... [Re: lahatte] #1103468
10/29/11 08:44 AM
10/29/11 08:44 AM
SW Fla.
CYACOP Offline
CYACOP  Offline
SW Fla.
Open hood and and use a regular volt meter and check battery voltage. Start car and check with it running. If it goes up chances are its charging, Rev up a little look for increased voltage.
Re: Is this a good Alternator test ... [Re: CYACOP] #1103469
10/29/11 09:06 AM
10/29/11 09:06 AM
TP Exit 7, NJ, USA
DANA60 Offline
DANA60  Offline
TP Exit 7, NJ, USA
with that way, and you can also put a tester directly to the alt. (big balck wire) and see what that voltage is. Or, you can pull your alt. and take it to, say, Auto Zone, who will check it for free. Battery is good I assume?
Re: Is this a good Alternator test ... [Re: DANA60] #1103470
10/29/11 09:16 AM
10/29/11 09:16 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I did that quick and easy test once in high school. My car(barracuda) was running with the headlights on, I pulled the cable and the car started to die so I put it back on. That was dumb lol, it burned out every single light bulb in the car that was on other than the tach light(autometer). Evidently the regulator told the alternator to go full steam and when the battery was hooked back up it caused a voltage spike. The only lights that worked after this were the turn signals, brake lights, and high beams, the only lights not turned on at the time.
I spent a good chunk of change at the parts store for all the lights.
I recently canned the mopar charging system. I put a GM CS130 alternator on the car. Now with headlights, electric water pump, fuel pump, and fan it idles at 13.9 volts. Thats with a 5" crank pulley even.
68 Barracuda Formula S 340
Re: Is this a good Alternator test ... [Re: Bad340fish] #1103471
10/29/11 10:51 AM
10/29/11 10:51 AM
I have the diagram to hook that one up. is there a special year/make to ask for and will some spacers and fabbing a simple bracket mount it or does it need a custom bracket
Re: Is this a good Alternator test ... [Re: SeventySatellite] #1103472
10/29/11 11:00 AM
10/29/11 11:00 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Bad Idea, don't do it.......if you want a "poor mans" test for the charging system quick diagnosis,...
Try this, with the car running, take a screwdriver and touch the bearing, located in the CENTER of the REAR CASE, if you feel magnetic attraction, the alternator is working, however, if the battery is still not charging, chances are it's the voltage regulator, this is just a "quick" diagnosis test to generally locate the issue,...you should have a meter to understand exactly where and what is going on in the system
mike
Re: Is this a good Alternator test ... [Re: DAYCLONA] #1103473
10/29/11 11:22 AM
10/29/11 11:22 AM
What Dayclona said. Yes rarely a diode or maybe something else inside the alt is reducing it's output but k.i.s.s. that'll quickly confirm/deny the alt as the prob then let you move on to the reg/grounds etc. #1 in electrical is a good battery that's been PROPERLY load tested to confirm it's good EDIT and first it must be fully charged for a valid test as in slow charge overnight
Re: Is this a good Alternator test ... [Re: RapidRobert] #1103474
10/29/11 12:46 PM
10/29/11 12:46 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Easy just take it to any Big Brand parts store.They will test the whole system free.I like load testing the alt.That way you know how many amps it puts out under a load.Rocky
Chrysler Firepower
Re: Is this a good Alternator test ... [Re: Bad340fish] #1103475
10/29/11 09:25 PM
10/29/11 09:25 PM
Coram, NY
Pool Fixer Offline
Pool Fixer  Offline
Coram, NY
I don't see the need to totally can the mopar charging system. Modify? YES... but you can easily run a 130 amp denso of an early 2000's chrysler product and retain the external regulator. Add a fat wire between alt and starter relay and it's good to go.
Re: Is this a good Alternator test ... [Re: SeventySatellite] #1103476
10/30/11 09:54 AM
10/30/11 09:54 AM
TP Exit 7, NJ, USA
DANA60 Offline
DANA60  Offline
TP Exit 7, NJ, USA
he bottom line is: What makes you think the charging system is bad? If your alt meter in the car shows a discharge then yes things need to be checked. If a volt meter is not showing more then 13.5-14.5, then things need to be checked. Yes, you could go to the GM style, but that's not ness. if things are checked and fixed. I, and I'm sure all Mopar owners, have had their issues with the stock charging systems for decades and they do work. Five items: Alternator, voltage regulator, wire conections (black from alt., VR field conections, bulkhead, alt. meter conection, redwire back out to battery) and battery. It's not complicated.
Re: Is this a good Alternator test ... [Re: RapidRobert] #1103477
10/30/11 01:10 PM
10/30/11 01:10 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I believe I asked for an alternator for a 91 buick century.
Mine is not stock under the hood at all and I am using a fabbed bracket that I bought. I have a small block with a mezziere electric water pump so the stock alternator mounting doesn't cut it.
Re: Is this a good Alternator test ... [Re: Pool Fixer] #1103478
10/30/11 01:15 PM
10/30/11 01:15 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I agree that can be done and would work great.
I only use the factory wiring for the lights and wipers, everything else runs off of a relay panel I made(elec water pump, fuel pump, fan, MSD.) I mainly went with the GM alternator as it fit the only bracket available for a small block with a mezziere water pump.
Re: Is this a good Alternator test ... [Re: SeventySatellite] #1103479
10/30/11 02:07 PM
10/30/11 02:07 PM
Central TX
roe Offline
roe  Offline
Central TX
I've done it many times, but I think I removed the neg cable, with no ill effects
1971 Plymouth Satellite
408/904 8 3/4 3.23 SG
