833 to 3g hemi How?
#1103399
10/28/11 08:29 PM
10/28/11 08:29 PM
Posts: 1,030 JAX FLA
Curt
JAX FLA
Is it no big deal now? Thanks Curt
Oh yeah...THAT'S gonna leave a mark!
Re: 833 to 3g hemi How?
[Re: JohnRR]
#1103401
10/28/11 11:06 PM
10/28/11 11:06 PM
Curt
JAX FLA
My concern is exactly that. Also have a 18 spline 833, so different bearing retainer size there as well. I would assume a hydraulic conversion as well?. Sure would like to use the dual disc set-up from the 2G hemi...minus the flywheel of course. Curt
[Re: Curt]
#1103404
10/29/11 12:05 PM
10/29/11 12:05 PM
Curt
JAX FLA
Cool, so it sounds like it is Do-able.. I will look around some more. Thanks Curt
[Re: savoy64]
#1103405
10/29/11 04:29 PM
10/29/11 04:29 PM
Posts: 75,071 U.S.S.A.
JohnRR
U.S.S.A.
you will need to buy a shim to place between the engine block and bellhousing---it is about 18 gauge and they are stamped out to fit exactly---bob
What is the shim needed for ?
[Re: savoy64]
#1103407
10/30/11 05:47 PM
10/30/11 05:47 PM
Posts: 25,902 Rio Linda, CA
John_Kunkel
Rio Linda, CA
18 gauge is only .050" thick.
[Re: savoy64]
#1103409
10/30/11 07:28 PM
10/30/11 07:28 PM
John_Kunkel
Rio Linda, CA
I was curious because I had read of swaps where no spacer was used and I found this quote from another source... "There is a slight 0.060-inch flexplate ring-gear misalignment due to the Hemi's slightly longer crankshaft offset. In theory, spacers/adapters are needed to make up the difference, but early installers (unaware of the difference) have reportedly just bolted everything up."
[Re: John_Kunkel]
#1103410
10/30/11 07:47 PM
10/30/11 07:47 PM
Curt
JAX FLA
And the pilot bushing??? Curt
[Re: Moparnut426]
#1103414
12/13/11 12:54 PM
12/13/11 12:54 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
my converter sits right against the flex plate. i can turn it but there is not that free play that we are accustomed too. i havent yet decided if i'm going to leave it this way yet or put a spacer in there
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: sixpackgut]
#1103415
12/13/11 12:56 PM
12/13/11 12:56 PM
sixpackgut
Charleston
also, can this punched from sheetmetal spacer be had cheap? who is the source?
[Re: Moparnut426]
#1103417
12/13/11 02:23 PM
12/13/11 02:23 PM
sixpackgut
Charleston
Ive tried to find one in lakewoods catalogue, but came up short. The only plate Ive ever found for a mopar is for a big block. I would think you could make a cardboard template and cut one to fit to give ya some freeplay there.
On auto versions you have to champfer the snout of the torque converter on some so it dosnt bind against the radious in the back of the crank flange. I personally took out a thrust bearing and crank in Dads 408 mopar performance stroker because the converter wouldnt go into the crank and kept constant pulling pressure on the thrust bearing.
Thanks mile high crank for helping me out.
Kasey
converter fits in crank fine but like you said, any pressure and you will take out the thrust is what i'm worried about. i will make my own spacer if i have to, it just seems like it should be a cheap item to buy
