Which valves, springs, etc for MP Hemi heads?
#1102932
10/27/11 09:18 PM
10/27/11 09:18 PM
Posts: 12,231 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
I got a deal on a new set of bare MP Hemi heads (P5153779). So I need all the valve gear. They will end up on a 528-540 inch street strip engine. Cam will probably be in the .625/260* range.
I know that the actual spring specs will come with the cam, but I would like to get some recommendations on what brand parts to use and who to get them from. I'm looking for bang for the buck here.
I have never bought complete valve set-ups for heads before, least of all Hemi stuff. I'll definitely spend what I need to spend to get quality pieces, I was just hoping to not waste money by buying overkill parts or buying from the wrong vendor and paying too much for the same stuff.
If it matters, I expect to send them to MCH for that "Magic Touch".
Thanks for the input!
Master, again and still
Re: Which valves, springs, etc for MP Hemi heads?
[Re: domingo]
#1102934
10/29/11 12:24 PM
10/29/11 12:24 PM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
What about wedge parts then? Where do you buy? Can you get quality and price in one place?
[Re: DaveRS23]
#1102935
10/29/11 01:39 PM
10/29/11 01:39 PM
Posts: 9,670 Lima, Peru
domingo
EL Master
EL Master
Lima, Peru
Id say give Jeff Koblinsky at Modern Cylinder Head a call. Or call Tim Banning www.forhemisonly.comThey will tell you whats the best you should use for your application.
