A/C VACUUM LINES E BODY WHERE DO THEY GO? #110266
08/25/08 08:22 PM
08/25/08 08:22 PM
Pennsylvania, USA
340propak Offline OP
Pennsylvania, USA
Does anyone have a diagram of where the A/C and heater vacuum lines from the heater control box go to on a 70 challenger? can't seem to find that anywhere and i didn't label them when i took this apart.
thanks
John
Re: A/C VACUUM LINES E BODY WHERE DO THEY GO? [Re: 340propak] #110267
08/25/08 09:27 PM
08/25/08 09:27 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
No diagram handy. They come off the heater box and plug in the controls inside the car. Then there is a rubber plug under the heater box in the firewall that the vacuum supply comes from the intake manifold. There will be one vacuum hose loose that plugs into the gromet/rubber plug at the firewall. The inside vacuum lines run over the top of the streering columm.
Re: A/C VACUUM LINES E BODY WHERE DO THEY GO? [Re: Challenger 1] #110268
08/25/08 10:11 PM
08/25/08 10:11 PM
Rochester HIlls, MI
Blue66Charger Offline
Rochester HIlls, MI
Detroit Musclecar Technologies - they sell the rebuild kit and has a great photo sequence on the HVAC box
Re: A/C VACUUM LINES E BODY WHERE DO THEY GO? [Re: Blue66Charger] #110269
08/26/08 01:40 PM
08/26/08 01:40 PM
None
71rm23 Offline
71rm23  Offline
None
Rebuilding mine right now.
Re: A/C VACUUM LINES E BODY WHERE DO THEY GO? [Re: Challenger 1] #110270
08/26/08 04:18 PM
08/26/08 04:18 PM
Pennsylvania, USA
Pennsylvania, USA
The picture helps a lot,but i can't tell where the vacuum lines go, I wanted to know where each line goes to vacuum actuators, the vacuum lines are color coded RED, YELLOW, WHITE,
and Black
thanks for the help
john
Re: A/C VACUUM LINES E BODY WHERE DO THEY GO? [Re: 340propak] #110271
08/26/08 05:12 PM
08/26/08 05:12 PM
its kinda nasty but you can use a clean length of hose and check each fitting [might have to block some off]by sucking on hose and work each switch/engage and trace them out.use a new inline fuel filter for lung protection
Re: A/C VACUUM LINES E BODY WHERE DO THEY GO? [Re: 340propak] #110272
08/26/08 06:44 PM
08/26/08 06:44 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
From the 70 Factory Service Manual
Click on attachment for larger picture.
Re: A/C VACUUM LINES E BODY WHERE DO THEY GO? [Re: Snoopy] #110273
08/26/08 07:24 PM
08/26/08 07:24 PM
Snoopy Offline
Snoopy  Offline
2
Re: A/C VACUUM LINES E BODY WHERE DO THEY GO? [Re: Snoopy] #110274
08/27/08 08:09 AM
08/27/08 08:09 AM
Pennsylvania, USA
Pennsylvania, USA
thanks, thats the diagram i was looking for!
should have known to ask you guys first instead of wasting time searching the web.
john
