E body A pillar Trim Why are they different? #1102541
10/27/11 12:39 PM
10/27/11 12:39 PM
Tenn.
jrwoodjoe Offline OP
Tenn.
I was cleaning up my A pillar Trim today and noticed that the lower screw holes are not the same distance from the end. In other words, one is lower than the other. One of trim pieces is original to the car the other is one I bought a while back. Did the lower screw hole change at some point from 70-74? If so, I may have to find another one. I am not at my garage right now so I can't check to see if that is the way it is supposed to be but I'm thinking not.
Joe
65 Barracuda
70 Challenger
Re: E body A pillar Trim Why are they different? [Re: jrwoodjoe] #1102542
10/27/11 12:43 PM
10/27/11 12:43 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
E-body A-pillar trim screw locations changed a couple times from 70 to 74
WHY, I have no idea.
Re: E body A pillar Trim Why are they different? [Re: jrwoodjoe] #1102543
10/27/11 01:04 PM
10/27/11 01:04 PM
DELAWARE
TONY_DAGOSTINO Offline
DELAWARE
this explains it
Re: E body A pillar Trim Why are they different? [Re: TONY_DAGOSTINO] #1102544
10/27/11 01:33 PM
10/27/11 01:33 PM
Tenn.
Tenn.
That's a great Photo Tony. Explains it perfectly. Seems that the one I bought to replace my broken one is a 71-73 piece. I also noticed that on the 71-73 piece, you can see a circular pattern in the grain where the screw hole for the 70 only piece would have been.
Thanks guys!
Joe
Re: E body A pillar Trim Why are they different? [Re: TONY_DAGOSTINO] #1102545
10/27/11 02:06 PM
10/27/11 02:06 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
73 Challenger SPD 927 of 1972...only the lower holes are drilled. These are the original trim pieces. There is extra material around the upper holes but they aren't drilled.
Re: E body A pillar Trim Why are they different? [Re: burdar] #1102546
10/27/11 03:45 PM
10/27/11 03:45 PM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
Same as mine. November actual production date (day after Thanksgiving). I am thinking a 73-74 piece.
Craig
