Re: qqRe: Std. Volume Oil Puimp or High Volume? [Re: Performance Only] #1102334
10/30/11 01:02 PM
10/30/11 01:02 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
Maybe side clearance? Or hes just that good.
Re: qqRe: Std. Volume Oil Puimp or High Volume? [Re: RemCharger] #1102335
10/30/11 01:05 PM
10/30/11 01:05 PM
Delray beach, Florida
P
Performance Only Offline
P
Yeah, that must be it.
machine shop owner and engine builder
Re: qqRe: Std. Volume Oil Puimp or High Volume? [Re: Performance Only] #1102336
10/30/11 02:32 PM
10/30/11 02:32 PM
New York, USA
Chargerfan68 Offline OP
New York, USA
I wish I was that good, but obviously it was a typo. The correct number was .0026" . I don't know where the 5 came from. Just a brain fart.
Thanks.
Re: qqRe: Std. Volume Oil Puimp or High Volume? [Re: Chargerfan68] #1102337
10/30/11 07:49 PM
10/30/11 07:49 PM
Thanks.
If a guy doesn't have a brain fart now and then his head constantly is full of gas My Hi Po street motors usually ended up with similar rod bearing clearances,I usually ended up with more than that My current pump gas 518 low deck stroker has .003 + on the rods and mains Works good, has lasted a long time so far
Re: qqRe: Std. Volume Oil Puimp or High Volume? [Re: Cab_Burge] #1102338
11/01/11 07:56 PM
11/01/11 07:56 PM
New York, USA
New York, USA
Thanks.
Thanks very much Cab. With the clearances in this engine, I think you are giving very valid advice. Sometimes I just need to double check myself.
Thanks to everyone also for their help.
Greg.
