Re: qqRe: Std. Volume Oil Puimp or High Volume?
[Re: Cab_Burge]
#1102338
11/01/11 07:56 PM
11/01/11 07:56 PM
Posts: 1,264 New York, USA
Chargerfan68
New York, USA
Maybe side clearance? Or hes just that good.
Yeah, that must be it.
I wish I was that good, but obviously it was a typo. The correct number was .0026" . I don't know where the 5 came from. Just a brain fart.
Thanks.
If a guy doesn't have a brain fart now and then his head constantly is full of gas My Hi Po street motors usually ended up with similar rod bearing clearances,I usually ended up with more than that My current pump gas 518 low deck stroker has .003 + on the rods and mains Works good, has lasted a long time so far
Thanks very much Cab. With the clearances in this engine, I think you are giving very valid advice. Sometimes I just need to double check myself.
Thanks to everyone also for their help.
Greg.
