Blowing head gaskets question #1102118
10/26/11 09:42 PM
10/26/11 09:42 PM
Bowling Green, KY
K
KY Charger Offline OP
K
Bowling Green, KY
I have a 360 with two 450 Holley's tunnel ram setup and compression of 11.2:1 I first blew the driver side head gasket, replaced it with a different type gasket and as soon as I fired it up to make sure nothing was leaking it blew the passenger side. The gaskets that blew was the Fel Pro 1008 Ihad a set of Mr Gasket that I put one on the driver side but plan on putting Cometic on both sides. Does anyone have any clue what could have caused the problem; they blew almost straight across from each other. The driver side was leaking about at the #5 cylinder and the passenger is around the #4 cylinder. I had tooling at my work check the driver side head on their flat stone with dykem paste and everything was good with it. I had 93 octane in it at the time the heads are ported J heads.
Re: Blowing head gaskets question [Re: KY Charger] #1102119
10/26/11 09:50 PM
10/26/11 09:50 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Did it blow #5 into the lifter valley? I had this problem on my blown 340. The culprit,detonation. Went thru a few sets of pistons and head gaskets. Then I discovered it had too much total timing for my combo. Pulled out 5 degrees. Same gaskets since 1991.
Doug
Re: Blowing head gaskets question [Re: dvw] #1102120
10/26/11 09:56 PM
10/26/11 09:56 PM
Guitar Jones Offline
11.2 with iron heads and pump swill, yeah, that could be a problem. What is you total timing? Have you jetted it at all? It could be very lean as well.
Re: Blowing head gaskets question [Re: Guitar Jones] #1102121
10/26/11 10:20 PM
10/26/11 10:20 PM
Bowling Green, KY
K
K
Bowling Green, KY
It's leaking antifreeze on the outside of the block, none getting in the oil or oil in the antifreeze. I believe its around 26 degrees at 2500 rpm
Re: Blowing head gaskets question [Re: KY Charger] #1102122
10/26/11 10:54 PM
10/26/11 10:54 PM
Ah, ok. My 360 did that as well. If it's not pouring out just kind of seeping it may stop on it's own but you may need to put sealer on the head bolt threads.
Re: Blowing head gaskets question [Re: KY Charger] #1102123
10/26/11 11:17 PM
10/26/11 11:17 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
did u retorque ur head bolts. i retorque them the next day. loosen one & torque it in sequence. 11-1, pump gas. never had a leak. using the same gasket as u are. some will say that isn't necessary, but i have no leaks. using the same gasket as u are. stay safe, seeya.
Re: Blowing head gaskets question [Re: rickraw] #1102124
10/28/11 01:22 AM
10/28/11 01:22 AM
Bowling Green, KY
K
K
Bowling Green, KY
Could the problem maybe be with the Flowkooler high volume water pump and and the combination of March Performance pulleys causing too much flow and pressure building up.
Re: Blowing head gaskets question [Re: KY Charger] #1102125
10/28/11 01:40 AM
10/28/11 01:40 AM
Finland
mafo Offline
mafo  Offline
Finland
you should not have any problems with fel-pro gaskets, to me it sounds like you need a new torque wrench
-65 Valiant,420", all motor,2700#, dot tires, 8,42 @ 160,2
Re: Blowing head gaskets question [Re: mafo] #1102126
10/28/11 01:42 AM
10/28/11 01:42 AM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
or the head is warped
home of the
Sox and Martin Hemi Duster
Re: Blowing head gaskets question [Re: HEMIFRED] #1102127
10/28/11 11:35 AM
10/28/11 11:35 AM
Mid Missouri
E
ETASPEN Offline
ETASPEN  Offline
E
Mid Missouri
Check to make sure the timing does not continue to climb w/RPM. Seen this happen w/some distributors, and eat headgaskets. I lock out my distributor's advance.
Re: Blowing head gaskets question [Re: ETASPEN] #1102128
10/28/11 11:40 AM
10/28/11 11:40 AM
On the newer blocks the head bolt holes are not blind, they go into the water jacket and need to be sealed.
Re: Blowing head gaskets question [Re: Guitar Jones] #1102129
10/28/11 12:56 PM
10/28/11 12:56 PM
California, USA!!!
W
WheelsUp73 Offline
WheelsUp73  Offline
W
California, USA!!!
The clue is the 10 head bolts SUCK. We had the same problem. The gaskets would not fail in the same place twice. The head was flat and the block was decked. I went to the cometics and have had 0 problems since. New video
http://youtu.be/1HtN08OzO0s
Re: Blowing head gaskets question [Re: WheelsUp73] #1102130
10/28/11 11:16 PM
10/28/11 11:16 PM
Long Beach, CA
Mike Swann Offline
Mike Swann  Offline
Long Beach, CA
Say that to the ford guys.
8.30's @3400 lbs
Re: Blowing head gaskets question [Re: Mike Swann] #1102131
10/29/11 12:58 AM
10/29/11 12:58 AM
California, USA!!!
W
WheelsUp73 Offline
WheelsUp73  Offline
W
California, USA!!!
I don't need to tell them something they all ready know!
Re: Blowing head gaskets question [Re: WheelsUp73] #1102132
10/29/11 01:49 AM
10/29/11 01:49 AM
Long Beach, CA
Mike Swann Offline
Mike Swann  Offline
Long Beach, CA
Maybe if they're going 6.20's with 60psi and 12:1, nawww.
http://www.youtube.com/watch?v=pMK7hOEGWSw
8.30's @3400 lbs
Re: Blowing head gaskets question [Re: KY Charger] #1102133
10/29/11 02:22 AM
10/29/11 02:22 AM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
In other words you are not BLOWING the head gaskets, as in the combustion chamber losing it's seal - you are leaking coolant. BIG difference.
IF your deck surfaces are too smooth, like they are when you use the scotchbrite discs to clean the old gaskets off, the heads can leak as you describe - graphite or composite gaskets do not like a polished surface. Also, any chance your head bolts are bottoming out on debris in the threads, and not getting full clamping pressure?
Free advice and worth every penny...
Factory trained Slinky rewinder.........
Re: Blowing head gaskets question [Re: Evil Spirit] #1102134
10/29/11 04:24 AM
10/29/11 04:24 AM
junction city oregon
V
viperblue72 Offline
viperblue72  Offline
V
I agree that its likely timing advancing too much. That's what caused problems for me when I stabbed in my new mp distributor and it had 55 degrees advance built in. Why mopar performance sells em like this is beyond me. The felpro should be fine at your level. The cometics are good but believe me they can be a pain to get to seal. So I don't recommend them unless you really need em. And at 11.2 I don't believe its necessary.
