Charger leaf springs: zinc interliners question
#1101980
10/26/11 04:28 PM
10/26/11 04:28 PM
Posts: 403 Western Oregon
bull
Western Oregon
I'm putting my new leaf springs back together with a rebuild kit that includes new zinc interliners - those thin metal spacers that go between each leaf. These interliners have the mounting hole drilled off-center which creates a long end and a short end. Which way does the long end go, toward the front or toward the back?
Looking at my original springs (which have been altered somewhat) the indication is that the long end went toward the front of the springs where the large bushing is. I don't know if a previous owner modified the interliners (why would he?) but someone did remove the rear straps, apparently for the purpose of more traction in drag racing. Logically it would seem that the long end should go toward the rear since there's more area behind the alignment bolt than in front of it (see pic for example).
I should also add that there are two short interliners that obviously go under the shortest leaf, the one at the bottom of the stack that has the part number. That one I know goes toward the front so assuming the rest follow suit, they should go toward the front too.
1968 Charger 383/2bbl/4spd (1 of 74)
1994 Dakota Sport 3.9L/AT/2WD
2003 Durango SLT 4.7L/AT/4X4
Yes, all Dodges and nothing else
Re: Charger leaf springs: zinc interliners question
[Re: bull]
#1101981
10/27/11 02:59 AM
10/27/11 02:59 AM
bull
Western Oregon
Nuthin? Well, don't feel bad. I asked three Mopar restoration guys and two suspension guys and I got 3 saying one thing and two saying the other.
[Re: 1969ronnie]
#1101984
10/27/11 04:42 PM
10/27/11 04:42 PM
bull
Western Oregon
Thanks. That's the direction I was leaning.
[Re: bull]
#1101985
10/28/11 06:19 AM
10/28/11 06:19 AM
Posts: 3,344 Central TX
roe
Central TX
Bull, where did you get your rebuild kit from? Im thinking of rebuilding mine instead of buying a new set and would like to know where to get the rebuild kits?
thanks roe
1971 Plymouth Satellite 408/904 8 3/4 3.23 SG
[Re: 1969ronnie]
#1101986
10/29/11 03:09 AM
10/29/11 03:09 AM
Posts: 2,679 Maple Ridge, BC, Canada
Barnabas_Kriss
bull, will a magnet stick to your interleafs because it shouldnt. they look like sheet metal cut out to look like zinc. and yes, long section forward. best,ronnie
The cheap rebuild kit I got off ebay had galvanized sheetmetal pieces rather than the correct zinc interliners. I ended up buying the correct zinc interliners from Frank Badalson.
[Re: Barnabas_Kriss]
#1101987
10/31/11 01:11 AM
10/31/11 01:11 AM
bull
Western Oregon
Turns out I got the cheap stuff too, but doesn't zinc-plated steel still stick to a magnet? Zinc plated nuts and bolt do.
Anyway, I got my kit from Valley Vintage and I would NOT recommend them at all. It was six days before the guy bothered to put the kit in the mail after I made an immediate payment. Of course it was in transit for another five days so 11 days total and now I find out the interliners are apparently junk. Wasted $60+ on those clowns.
Also, only two of the bands I got in the kit work. I don't know how long the rear bands need to be to go around four leaves, but I do know that the 8 3/8" bands don't reach. The other choices are 9" and 9.5".
[Re: bull]
#1101988
11/01/11 02:30 PM
11/01/11 02:30 PM
Posts: 299 Hinckley, Ohio
KWF340
Hinckley, Ohio
Not doubting you bull - just pointing out their web site says the interliners are zinc. V281 Quote:
1968 Charger R/T, 440 Auto, GG1; 1969 Super Bee, 383, 4-speed, T5; 1969.5 Road Runner, 440-6, 4-speed, 96; 1970 Duster 340, 4-speed, EV2; 1970 Charger R/T SE, 440 (496), Auto, EB3; 1970 Dart Swinger 340 (416), 4-speed, EV2; 1970 Corvette coupe, LS5, 4-speed, Daytona yellow; 2000 Corvette coupe, LS1, 6-speed, Twin Turbo, Torch red.
[Re: Sunroofcuda]
#1101995
01/06/12 04:03 AM
01/06/12 04:03 AM
Posts: 1,655 Cut and Shoot, TX
kentj340
Cut and Shoot, TX
Just bought the YearOne BH115 leaf spring rebuild kit. Lists for $69.99, but I waited for a 30% off sale and got it for $48.99.
They have a no questions return policy, if you don't like what they send.
[Re: kentj340]
#1101996
01/06/12 10:34 AM
01/06/12 10:34 AM
Posts: 8,409 Highland, MI.
Sunroofcuda
Highland, MI.
That's a killer price. Year One is not making ANY on ths kit for that price I can tell you. You'll be using my bands...........
[Re: kentj340]
#1101997
01/06/12 09:05 PM
01/06/12 09:05 PM
Posts: 3,704 MICHIGAN
DynoDave
MICHIGAN
Does this kit have zinc for sure? Or is that why you are referencing the return policy...just in case?
[Re: rarefish]
#1101999
01/08/12 10:55 PM
01/08/12 10:55 PM
Posts: 2,255 New York
rarefish
New York
Year One lists three different kits, but they use the same picture to illustrate for all three. Quite a difference in price between the three.
BH115 $69.99 Leaf spring rebuild kit for all 1968-1974 Chrysler models with small-block V8, 383, and 400 engine. Kit includes correct metal straps with rubber insulators, plastic interliners and zinc interliners. Kit rebuilds both left and right rear springs.
BH116 $129.99 Leaf spring rebuild kit for 1967-1972 Chrysler B-body models with 440, 440-6 and Hemi engine. Kit includes correct metal straps with rubber insulators, plastic interliners, zinc interliners.
BH117 $109.99 Leaf spring rebuild kit for 1970-1971 Chrysler E-body models with 440, 440-6 and Hemi engine. Kit includes correct metal straps with rubber insulators, plastic interliners, zinc interliners.
