Duster Popout window Weatherstrip replacment - HELP #1101976
10/26/11 04:17 PM
10/26/11 04:17 PM
United States
STLDuster Offline OP
United States
I have the rear pop out windows out of my '74 Duster. I ordered the replacement weather striping seals from Steele Rubber. They are supposed to be delivered today. Has anyone had any experience replacing these?
I was looking at the pop out windows last night and it looks like they are riveted together with a few LONG rivets. I don't really want to go cutting away on rivets that I can't replace.
Has anyone ever replaced these seals before?
"No great genius has ever existed without some touch of madness." - Aristotle
Re: Duster Popout window Weatherstrip replacment - HELP [Re: STLDuster] #1101977
10/26/11 05:44 PM
10/26/11 05:44 PM
ill
dennismopar73 Offline
ill
the weather strip is easy, just change out the rivits ,
the front brushes are a little tricky tho
Re: Duster Popout window Weatherstrip replacment - HELP [Re: dennismopar73] #1101978
10/27/11 01:32 PM
10/27/11 01:32 PM
United States
United States
So just cut out the long rivet and replace it with two shorter ones (one from either side)?
Re: Duster Popout window Weatherstrip replacment - HELP [Re: STLDuster] #1101979
10/28/11 12:57 PM
10/28/11 12:57 PM
Washington State
70Duster440 Offline
70Duster440  Offline
Washington State
A short pop rivet available from your local hardware store on each side will do it. You may have to ream the hole ever so slightly for it to fit.
