ProCharged HEMI: will CNC ported heads make a diffrnce? #1101629
10/25/11 07:36 PM
10/25/11 07:36 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Hi!
If building a 540 cid pro charged hemi to make around 1500 hp.
Would you think having CNC ported heads, vs stock out of the box heads with just a hand port cleanup, port match and bowl blending would make any difference?
Re: ProCharged HEMI: will CNC ported heads make a diffrnce? [Re: domingo] #1101630
10/26/11 05:10 PM
10/26/11 05:10 PM
QLD Australia
Keith Black® Offline
QLD Australia
yep.
Darren Beale
Keith Black Racing Engines®
Re: ProCharged HEMI: will CNC ported heads make a diffrnce? [Re: Keith Black®] #1101631
10/30/11 05:06 AM
10/30/11 05:06 AM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
forced induction needs little or no work on a port the size of the Hemi to produce 1500 hp
we made 1650hp on alky using a s/b head a 2.150 intake that only flowed 250 CFM @ .500
home of the
Sox and Martin Hemi Duster
Re: ProCharged HEMI: will CNC ported heads make a diffrnce? [Re: HEMIFRED] #1101632
11/01/11 02:45 AM
11/01/11 02:45 AM
Bama
Randy.. Offline
Randy..  Offline
Bama
so a set of Victors with just the ports smoothed and twin 76mm should make 900hp at 15lbs or less?
