Why 2 Rear Seat Catches per side? #1101286
10/25/11 01:43 AM
10/25/11 01:43 AM
Mississippi
lahatte Offline OP
lahatte  Offline OP
Mississippi
On my 1971 Challenger convertible there are 2 rear seat catches per side, one right in front of the other. Why are there 2?
Re: Why 2 Rear Seat Catches per side? [Re: lahatte] #1101287
10/25/11 07:42 AM
10/25/11 07:42 AM
Sharpsburg Maryland
440farmer Offline
440farmer  Offline
Sharpsburg Maryland
My wife's 71 chally vert has the same???
Re: Why 2 Rear Seat Catches per side? [Re: 440farmer] #1101288
10/25/11 09:00 AM
10/25/11 09:00 AM
WI
RestoRick Offline
RestoRick  Offline
WI
I've seen the same thing on all the E-body convertibles I've worked on.
I think that back floor pan was preassembled with the hardtop seat catch location. When used on a convertible, the second catch was added in the correct spot.
If you look at the total production of hardtops vs. convertibles, it probably wasn't worth messing with a second pan.
Rick
Re: Why 2 Rear Seat Catches per side? [Re: RestoRick] #1101289
11/04/11 12:13 AM
11/04/11 12:13 AM
Mississippi
lahatte Offline OP
lahatte  Offline OP
Mississippi
That makes sense. Thanks.
Re: Why 2 Rear Seat Catches per side? [Re: lahatte] #1101290
11/06/11 09:17 PM
11/06/11 09:17 PM
Rockford, IL.
Ruppman Offline
Ruppman  Offline
Rockford, IL.
My 1970 is the same way.
mark
Re: Why 2 Rear Seat Catches per side? [Re: Ruppman] #1101291
11/07/11 12:46 PM
11/07/11 12:46 PM
our 70 chally vert had two on the pass side. original floors in the car. I ended up removing the additional one on the pass side due to some interference with getting the seat bottom to stay down correctly.
