Harland Sharp rockers and stock valve covers? #1101038
10/24/11 08:50 PM
10/24/11 08:50 PM
Connecticut
5126brl No more Offline OP
Connecticut
Looking into getting a set of H/s rockers " 1.6" ratio and heard that they may not fit under a stock steel valve cover? Anyone know the facts on this? Thanks
Re: Harland Sharp rockers and stock valve covers? [Re: 5126brl No more] #1101039
10/24/11 08:51 PM
10/24/11 08:51 PM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
They fit.
Re: Harland Sharp rockers and stock valve covers? [Re: scatpacktom] #1101040
10/24/11 09:02 PM
10/24/11 09:02 PM
Connecticut
Connecticut
Thanks Tom,
Re: Harland Sharp rockers and stock valve covers? [Re: 5126brl No more] #1101041
10/24/11 09:53 PM
10/24/11 09:53 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
On mine, I had to bevel the corners of the hold-downs at both ends, and ball-peen some clearance at the oil baffles. That's with the 1.6 HS setup on Eddy heads. Wasn't a big deal, but I about had a heart attack first time I heard the racket.
Re: Harland Sharp rockers and stock valve covers? [Re: 5126brl No more] #1101042
10/24/11 10:27 PM
10/24/11 10:27 PM
Medina, OH
dart440_72 Offline
dart440_72  Offline
Medina, OH
Mine fit as well. No problems.
Re: Harland Sharp rockers and stock valve covers? [Re: dart440_72] #1101043
10/24/11 10:34 PM
10/24/11 10:34 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
you can get some clay from a craft store and chech by cycling thru the lift.i did not have a problem with the taller covers[1973 up i think]
Re: Harland Sharp rockers and stock valve covers? [Re: 5126brl No more] #1101044
10/24/11 11:18 PM
10/24/11 11:18 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
Most often they fit, there does seem to be some slight differences in some stock valve covers...as mentioned, sometimes its just the corners and or baffles. I can take care of you on Harlands, drop me a PM or email if you wish....
RIP Monte Smith
Re: Harland Sharp rockers and stock valve covers? [Re: CompWedgeEngines] #1101045
10/25/11 02:04 AM
10/25/11 02:04 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I wanted stock looking covers as I wanted the Max Wedge look so I used these which I think are old Eddy valve covers. They were chrome but scratched which I did not care as I was painting them orange anyway. They look a bit taller then stock but look close to stock to me. I use Hughes 1.6 roller tip rockers with .630 lift on my 63's eng and they work fine. Ron
