Heater box refreshening - 1972 A-body non A/C #1100995
10/24/11 07:25 PM
10/24/11 07:25 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
In case anyones intersted. I though this might be a good post to do.
This a freshening up of a non a/c heater box for a 1972 Demon.
Most probably realize they are not hard to do, but can be more time consuming than one may think.
Just to give one an idea, Start to finish was just a click over 7 hours.
So here goes.
The mess I started with
Re: Heater box refreshening - 1972 A-body non A/C [Re: gtx6970] #1100996
10/24/11 07:26 PM
10/24/11 07:26 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
2
Re: Heater box refreshening - 1972 A-body non A/C [Re: gtx6970] #1100997
10/24/11 07:27 PM
10/24/11 07:27 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Best advice I can give anyone is, take LOTS of pictures . You WILL need them.
Re: Heater box refreshening - 1972 A-body non A/C [Re: gtx6970] #1100998
10/24/11 07:29 PM
10/24/11 07:29 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Take it all the way down to an empty case. To clean out the 40 years worth of leaves and debris.
Re: Heater box refreshening - 1972 A-body non A/C [Re: gtx6970] #1100999
10/24/11 07:36 PM
10/24/11 07:36 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
next
Re: Heater box refreshening - 1972 A-body non A/C [Re: gtx6970] #1101000
10/24/11 07:37 PM
10/24/11 07:37 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
All the seals on the interior doors just crumbles when touched.
Re: Heater box refreshening - 1972 A-body non A/C [Re: gtx6970] #1101001
10/24/11 07:40 PM
10/24/11 07:40 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Vent door hinges were frozen and the door was real tough to open or close.
Which caused 2 issues.
1 - a cracked door
Re: Heater box refreshening - 1972 A-body non A/C [Re: gtx6970] #1101002
10/24/11 07:41 PM
10/24/11 07:41 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
2nd - rivets pulled thru the box
Re: Heater box refreshening - 1972 A-body non A/C [Re: gtx6970] #1101003
10/24/11 07:44 PM
10/24/11 07:44 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
But, Not a real bad fix. And I added a piece of sheetmetal to the inside of the box to give it some added strength.
Re: Heater box refreshening - 1972 A-body non A/C [Re: gtx6970] #1101004
10/24/11 07:48 PM
10/24/11 07:48 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
After a breif quick trip thru the glass bead cabinet, I used Seymours stainless steel paint for all the doors and linkages.
Then using one of the gasket kits from DMT.
It starts to go back together.
Re: Heater box refreshening - 1972 A-body non A/C [Re: gtx6970] #1101005
10/24/11 07:50 PM
10/24/11 07:50 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
How did you fix the fiberglass damage?
Re: Heater box refreshening - 1972 A-body non A/C [Re: gtx6970] #1101006
10/24/11 07:52 PM
10/24/11 07:52 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Once tested, the motor and the vent door were shot with single stage enamel thru an HVLP gun. Sprayed with gloss black , dulled ever so slightly to take the super high gloss off of the finish.
Also, put in a brand new heater core as well. My local jobber actually had one on the shelf
Re: Heater box refreshening - 1972 A-body non A/C [Re: gtx6970] #1101007
10/24/11 07:55 PM
10/24/11 07:55 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Go over the box itself in the glass bead cabinet to clean it up. Then just go over it with Eastwoods diamond clear to bring the luster back.
That wiring bracket riveted to the case had to be replaced( originally was pretty rusty)
Bent up a simple piece of stainless and just dipped in vinyl coating to regain the original look of the original. Then put back on with the original style tube rivet.
Re: Heater box refreshening - 1972 A-body non A/C [Re: gtx6970] #1101008
10/24/11 08:00 PM
10/24/11 08:00 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
And I had a local print shop make me a stamp to put the assy pt number back on it.
Re: Heater box refreshening - 1972 A-body non A/C [Re: Morty426] #1101009
10/24/11 08:06 PM
10/24/11 08:06 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Filled it with 2 part fiberglass resin and fiberglass matting to fill the hole.
Then once I had a replacement cable bracket, it was revited back on with a piece of sheetmetal inside the box to prevent the rivets from pulling thru or breaking the repair back out.
Fortunately both repairs were under brackets and can't be seen once the box as back together. So outward visiblity to match the boxes original fibered finish was not an issue.
Re: Heater box refreshening - 1972 A-body non A/C [Re: gtx6970] #1101010
10/25/11 02:10 PM
10/25/11 02:10 PM
Oakville, Ontario, Canada
CDN72SE Offline
CDN72SE  Offline
Nice work.
Re: Heater box refreshening - 1972 A-body non A/C [Re: gtx6970] #1101011
10/25/11 02:50 PM
10/25/11 02:50 PM
BC
70RT27N Offline
70RT27N  Offline
BC
Mind if I ask what you used to install the original style tube rivets?
I want to use these rivets on my heater box, but I've never used them before.
Thanks.
Re: Heater box refreshening - 1972 A-body non A/C [Re: 70RT27N] #1101012
10/25/11 02:59 PM
10/25/11 02:59 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
there are several ways to compress them.
I'm lucky, a friend of mine has the tools and I just borrow his.
But the ones I use go in an air hammer - http://www.rivetsinstock.com/rivet-tools/solid-semitubular-rivet-tools.html
Re: Heater box refreshening - 1972 A-body non A/C [Re: gtx6970] #1101013
10/25/11 03:56 PM
10/25/11 03:56 PM
Crook County, ILL
Mastershake340 Offline
Crook County, ILL
Great stuff Bill! I have my T/A's heater box stored away upstairs awaiting restoration, and after reading your thread, I am tempted to dig it out and using your info, try to restore it myself.
Re: Heater box refreshening - 1972 A-body non A/C [Re: Mastershake340] #1101014
10/25/11 05:24 PM
10/25/11 05:24 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Brad,
give it a try. what do you have to lose.
I have a 1969 B-body A/C box on the table right now. They look more intimidatiing than they really are.
Considerably more complicated than this non a/c A-body box. But so far it's not to bad.
I have to get the heater core - recored and the evaporator ck'd out while I have it apart.
My best advise - take LOTS of before and during pictures. Believe me, you'll need them.
