Need a quick fix #1100987
10/24/11 07:07 PM
10/24/11 07:07 PM
Anywhere the British Secret Se...
Moonraker Offline OP
I was putting my intrument panel back together in my 74 duster after getting the bezel restored and snapped one of the plastic posts off the back of the bezel putting a screw back in(guessing it was already cracked or something and I never noticed). Barely applied any pressure and off it came. Any ideas on how to reattach it with a certain amount of strength to it enough to hold the bezel and cluster together on that corner? Adhesives or something along those lines? Thanks for the help!
Re: Need a quick fix [Re: Moonraker] #1100988
10/24/11 07:14 PM
10/24/11 07:14 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
http://www.amazon.com/J-B-Weld-8237-Kwik-Plastic/dp/B003S2E4UE and probably available at a parts store or hardware store.
Re: Need a quick fix [Re: Moonraker] #1100989
10/24/11 07:17 PM
10/24/11 07:17 PM
On may way to the store thanks!
Re: Need a quick fix [Re: Moonraker] #1100990
10/24/11 07:19 PM
10/24/11 07:19 PM
Alaska
73rrak Offline
73rrak  Offline
Alaska
Use this stuff http://www.autobodytoolmart.com/sem-bumper-repair-68422-p-16700.aspx You can get it at your autobody paint supply place. I used it to glue the broken studs back on my center console and the passenger side dash filler on my 73 Roadrunner and it worked great. I think it was $9 or $10 for it.
