Hey gang.
Was curious. I have a couple of the Bendix boosters that I've had for years. I want to verify they, or the one on my '69 Charger 500, work properly. The 500 doesn't move under it's own power yet. Part of the process to get that going is getting the hydraulic brake system up to speed. As you know, the booster's part of the system. The motor runs, so I can create vacuum as a source. Right now I have the original booster and master cylinder on the car. The master cylinder's shot as far as it's has no fluid in it and a lot of surface corrosion.
Thanks.
Troy
TroyHouston Mopar Connection Club'69 Charger Daytona 440 - auto - 4.10 Dana (now with 426 hemi)
