Ball joint replacement 2006 Ram #1100540
10/24/11 09:16 AM
10/24/11 09:16 AM
NC
DCM71cuda Offline OP
NC
My truck is approaching 200K miles. While changing oil yesterday I noticed the lower ball joint boots were shot. Given the mileage, I figure its worth getting them all replaced. It's not a job I want to do myself.
What is a ballpark cost to have all four (uppers and lowers) replaced?
Thanks.
Re: Ball joint replacement 2006 Ram [Re: DCM71cuda] #1100541
10/24/11 10:12 AM
10/24/11 10:12 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
1500, 2500 or 3500 , 2wd or 4wd ??
Re: Ball joint replacement 2006 Ram [Re: JohnRR] #1100542
10/24/11 11:46 AM
10/24/11 11:46 AM
NC
NC
2WD 1500
Re: Ball joint replacement 2006 Ram [Re: DCM71cuda] #1100543
10/24/11 11:55 AM
10/24/11 11:55 AM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Thanks.
The Dodge Ram & Dakota trucks are hard on ball joints especially the lower..
If never changed, you need to cut out the rivets..
Takes time with a torch..
Just my $0.02..
