Has anyone had a problem with a bolt in sway bar ?? #110035
08/25/08 09:21 AM
08/25/08 09:21 AM
MA
limelight440 Offline OP
MA
1970 Roadrunner 493+6 4 speed (moderate street use)
I have a 1" "Bolt IN" sway bar kit from just suspension.
The LCA's with sway bar mount that I have were
rusted VERY badly, so I opted for the bolt on kit
for a set of "non sway" LCA's
The sway bar has been in the car (driven once) but
not hooked up.
Has anyone ever had a problem with bolt in sway bars??
I'm nervous about hooking it up with out
welding....looking for feedback
Thanks,
Mike
Re: Has anyone had a problem with a bolt in sway bar ?? [Re: limelight440] #110036
08/25/08 07:53 PM
08/25/08 07:53 PM
templeton,ma
coro500net Offline
coro500net  Offline
templeton,ma
I have the same set up on my 65 Coronet and it
is bolted in,works fine.The only concern I had is
how close the bar is to the crank pulley,dosent
touch but is very close.
