What items were installed prior to rear undercoating? #1099166
10/22/11 12:20 PM
10/22/11 12:20 PM
Reno, Nevada
NV69B7RR Offline OP
NV69B7RR  Offline OP
Reno, Nevada
Besides the rear axle bump stops, gas tank, sender and fuel lines?
Also for certain cars the ECS system would be installed too. ANything else?
Brake lines were installed afterward from what I've read and noticed on my car.
Re: What items were installed prior to rear undercoating? [Re: NV69B7RR] #1099167
10/22/11 01:29 PM
10/22/11 01:29 PM
K
kielbasa Offline
kielbasa  Offline
K
sway bar and mounts (if your car had them)....
Re: What items were installed prior to rear undercoating? [Re: kielbasa] #1099168
10/22/11 09:07 PM
10/22/11 09:07 PM
Fremont, CA.
Topcat Offline
Topcat  Offline
Fremont, CA.
If the car had heat shields (like E Bodies), they were on prior to undercoating.
Re: What items were installed prior to rear undercoating? [Re: Topcat] #1099169
10/22/11 09:14 PM
10/22/11 09:14 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Just about everything, but it may depend some on the model year & assembly plant.
Re: What items were installed prior to rear undercoating? [Re: Alaskan_TA] #1099170
10/22/11 10:41 PM
10/22/11 10:41 PM
Ridgeland Wi
mopars_1 Offline
mopars_1  Offline
Ridgeland Wi
shocks were. I dont think the seats were, I belive that that holes were taped over
1971 Plymouth Duster 340 auto
1937 Plymouth PT50
1969 Dodge Dart Swinger 340 4 speed
2013 Ram laramie 2500 hemi
2008 Harley FLSTSB springer
Re: What items were installed prior to rear undercoating? [Re: NV69B7RR] #1099171
10/22/11 11:01 PM
10/22/11 11:01 PM
Ohio
C_B5 Offline
C_B5  Offline
Ohio
Seat belts were already installed as the tips of the bolts are usually undercoated
Any body plugs and bumper brackets which means bumper also as it was installed as unit
Re: What items were installed prior to rear undercoating? [Re: C_B5] #1099172
10/23/11 10:50 AM
10/23/11 10:50 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Rear axle and springs were not installed. There was undercoating overspray behind my front spring hangers. Agree that seat belts were installed and had overspray on the anchor bolt ends.
