1970 PP833 18spline 4 speed question *DELETED* #1099081
10/22/11 09:24 AM
10/22/11 09:24 AM
Paradise Pa
jdprdise Offline OP
jdprdise  Offline OP
Paradise Pa
Post deleted by jdprdise
Re: 1970 PP833 18spline 4 speed question [Re: jdprdise] #1099082
10/22/11 09:46 AM
10/22/11 09:46 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
676 is the last 3 digits of the part number, it's used to identify the trans at the factory so they put the right trans behind the engine on assembly line.
Yes an A body tail will bolt on , you also have to change the mainshaft and swap out the rear 308 bearing for a 307 bearing to fit the A body tail.
Re: 1970 PP833 18spline 4 speed question [Re: JohnRR] #1099083
10/22/11 10:03 AM
10/22/11 10:03 AM
Paradise Pa
jdprdise Offline OP
jdprdise  Offline OP
Paradise Pa
Thanks alot for the info John.
Re: 1970 PP833 18spline 4 speed question [Re: jdprdise] #1099084
10/22/11 12:00 PM
10/22/11 12:00 PM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
Came out of a 70 B body. You should post the VIN stamping. Who knows, someone might be lucky enough to get their original trans back.
MB
