Re: i hit my mark, new best
[Re: 383man]
#1098688
10/22/11 12:02 PM
10/22/11 12:02 PM
Posts: 939 glendora, ca.
Deepockets
glendora, ca.
the air was good. , 1500 1600. now the big question from all you guys, is what does the car weigh? some one here has to have something similar. the hood, fenders, deck are glass. the windows are original,.083 moly cage with foward bars, pair kirkey seats with carpet and padding on floor, aluminum divider between trunk and rear area,alum door pannels, no rear seat, has stock dash, one battery at 42 lbs and the big block based from alum. 5 gal rci plastic tank.
[Re: Deepockets]
#1098689
10/22/11 12:07 PM
10/22/11 12:07 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
2800 or less i bet. how much did your 60 ft improve from previos best?
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: Deepockets]
#1098691
10/22/11 10:32 PM
10/22/11 10:32 PM
Posts: 4,066 Mo.
racerx
Mo.
with all the little changes, i was destened to hit the 5.99 mark in the 1/8th. well, i did. the best of last night was 5.93 @ 115.86 mph. the best before was 6.03 @ 114 mph. i dont think i have enought time in my life to make one change at a time, so this is what i changed. i put the penske d/a coil overs on, moved the ladder bar up 1 hole, new 29 x 11.00 hoosier's with the standard side wall (i had the stiff side wall before), put the 1" spacer under the carb and jetted the main up from 86 to 90. all said and done i'm please with the over all performance. so now i can finally say, "i'm done spending money"
http://www.bowtie0069.fotki.com/2011-irwindale-pix-1/10-20-11-irwindale-pix/img-7581.html
Can u post your 330'time?.......Thax.
[Re: Kudakidd]
#1098695
10/23/11 09:13 PM
10/23/11 09:13 PM
Deepockets
glendora, ca.
Congrats on a great run. But honestly I feel like an 1/8 mile is like premature withdrawal.
i'd tend to agree, this 1/8th track (irwindale or toyota speedway) is like 10 minutes from the house and is conveinent as all heck. it passifies my racing needs till i take the duster out to fontana 1/4 mile. the local 1/8th track does not do prep work to warrent much faster cars so i wont run the duster there. they dont even have anything to drag rubber. any how i'll be takeing the duster out to the psca in a couple of weeks. it's best is 8.42 @ 162 mph on the motor. the car is only certed to 8.50 so i'm not looking to go any faster.
[Re: Big Squeeze]
#1098697
10/24/11 09:26 AM
10/24/11 09:26 AM
Posts: 3,210 robin hood country
deaks
robin hood country
Have you got a full size pic of the Dart and is it A body B5.
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
