MAX AIR PRESSURE IN M/T SPORTSMAN FRONTS??? #1098617
10/21/11 05:35 PM
10/21/11 05:35 PM
Clinton Twp... north of Deetro...
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
The sidewall says 30 lbs. MAX. These are the 4-ply,NOT the 8-ply for heavier cars. My GTX weighs 3500 lbs..3730 with me in it. What's the consensus on pumping them up a bit for the track? I have been setting them at 30 for the street...35 at the track. Would 40-45 be un-wise,i.e. dangerous? Thanks in advance! Randy B.
Re: MAX AIR PRESSURE IN M/T SPORTSMAN FRONTS??? [Re: Labratt] #1098618
10/21/11 05:38 PM
10/21/11 05:38 PM
Now - Port Orange,Fla. Former...
MIKES_DUSTER Offline
I think I ran 35lbs in mine.
Re: MAX AIR PRESSURE IN M/T SPORTSMAN FRONTS??? [Re: Labratt] #1098619
10/21/11 06:42 PM
10/21/11 06:42 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Randy... I've run as high as 45 in my front runners
Re: MAX AIR PRESSURE IN M/T SPORTSMAN FRONTS??? [Re: MR_P_BODY] #1098620
10/21/11 07:18 PM
10/21/11 07:18 PM
mi usa
O
old yeller Offline
old yeller  Offline
O
mi usa
50 psi.
Re: MAX AIR PRESSURE IN M/T SPORTSMAN FRONTS??? [Re: MIKES_DUSTER] #1098621
10/21/11 07:44 PM
10/21/11 07:44 PM
Renton Washington
Triple Threat Offline
Renton Washington
My 4 ply 26's were always above 40, usually 45+ Never an issue. I can tell you the car drive 100 times better with a radial on the front though.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: MAX AIR PRESSURE IN M/T SPORTSMAN FRONTS??? [Re: Triple Threat] #1098622
10/21/11 08:43 PM
10/21/11 08:43 PM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Bob..with a "heavy" car,you think 50 lbs. is safe? There's a warning on the side wall that says "tire could explode if inflated OVER 40 lbs"!!! Using bias-ply slicks...probably a good idea to stick with BIAS front tires!..MUCH MORE stable on the top end! Ask me how I know!
Re: MAX AIR PRESSURE IN M/T SPORTSMAN FRONTS??? [Re: Labratt] #1098623
10/21/11 09:08 PM
10/21/11 09:08 PM
mi usa
O
old yeller Offline
old yeller  Offline
O
mi usa
STABLE?, i go threw the traps @ 171 mph in the 1/4 mile and the roadrunner has weighed over 3,500lbs...with 50 lbs of front air pressure...i give up with you people!!!
Re: MAX AIR PRESSURE IN M/T SPORTSMAN FRONTS??? [Re: old yeller] #1098624
10/21/11 09:13 PM
10/21/11 09:13 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
I adjust them anywhere from 25 to 45 psi ?? what ever we need..I never had them to 50..but if bird says so..I believe it.
Re: MAX AIR PRESSURE IN M/T SPORTSMAN FRONTS??? [Re: old yeller] #1098625
10/22/11 12:43 AM
10/22/11 12:43 AM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Bird..my STABLE comment was directed toward Dustin,who suggested running radials on the front! Not a good idea when running bias-ply slicks on the back! ...been there,done that! I'll try 50 lbs. in the Mickey's tomorrow at the track! 171mph??? ...
Re: MAX AIR PRESSURE IN M/T SPORTSMAN FRONTS??? [Re: Labratt] #1098626
10/22/11 01:01 AM
10/22/11 01:01 AM
South Jersey, NJ
DragDart360 Offline
DragDart360  Offline
South Jersey, NJ
70 Dart Swinger, 2850 lbs
SB 408, Bullet roller 264/268 @50 .636 SSDS stage 2 Edelbrock heads, 1 7/8 Headmans, 1050 dominator by Dom, 9.867 @ 133
Re: MAX AIR PRESSURE IN M/T SPORTSMAN FRONTS??? [Re: Labratt] #1098627
10/22/11 10:00 AM
10/22/11 10:00 AM
tboomer Offline
tboomer  Offline
Randy...I run 36-37# in mine...Depends on reaction times..
Re: MAX AIR PRESSURE IN M/T SPORTSMAN FRONTS??? [Re: tboomer] #1098628
10/22/11 10:05 AM
10/22/11 10:05 AM
ill
dennismopar73 Offline
ill
I agree , track conditions, normal is @ 30-35#
