Trans broke please help! #1098513
10/21/11 10:13 AM
10/21/11 10:13 AM
SE Kansas
I
indytex96 Offline OP
I
SE Kansas
69 road runner 383 auto. Went to leave for work this morning started car went to shift to neutral felt tranny grab reverse a little on my way there warmed up car and then nothing. No reverse or drive at all but when I shift to park I can rock the car and feel that the park rod is engaging. Fluid level good and linkage moving lever on trans. Any ideas on what would have happened to cause this? Thanks Moparts!
Re: Trans broke please help! [Re: indytex96] #1098514
10/21/11 10:18 AM
10/21/11 10:18 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Check the fluid in N (like you should), and then check it in Park. It should read higher in park. If it's the same most likely the pump isn't doing it's job.
Re: Trans broke please help! [Re: J_BODY] #1098515
10/21/11 12:10 PM
10/21/11 12:10 PM
SE Kansas
I
I
SE Kansas
Would the pump just go out like that? Worked fine before parking it yesterday?
Re: Trans broke please help! [Re: indytex96] #1098516
10/21/11 02:34 PM
10/21/11 02:34 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Yes, when pumps fail they do it spontaneously.
Re: Trans broke please help! [Re: John_Kunkel] #1098517
10/22/11 01:33 PM
10/22/11 01:33 PM
SE Kansas
I
I
SE Kansas
Well upon checking fluid levels I assume you are correct as there was no change hardly at all between park and nuetral. So my next question would be can I just simply drop the trans and replace pump without any issues or am I oversimplifying this? Thanks again for the help!
Re: Trans broke please help! [Re: indytex96] #1098518
10/22/11 02:04 PM
10/22/11 02:04 PM
indiana
mcmopars Offline
mcmopars  Offline
indiana
yeeeeeep,just pull er down and swap er out.
