Pipemaster #1098428
10/21/11 06:05 AM
10/21/11 06:05 AM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
For all u DIY'ers ever use them?I'm thinking of investing in a couple(1 5/8,1 1/4) of them,seems a little expensive but i think there r worth the price considering the time save trying to fit joints I've once seen this episode on the Power block tv were they used a piece of cardboard trimmed as a template to form a joint anyone ever did this............Thax
Re: Pipemaster [Re: racerx] #1098429
10/21/11 09:18 AM
10/21/11 09:18 AM
Guitar Jones Offline
I like to use Zig Zag 1 1/2 to form my joints.
Sorry couldn't resist...
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: Pipemaster [Re: racerx] #1098430
10/21/11 10:02 AM
10/21/11 10:02 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I've used PVC tubing to layout headers but most of
the time I dont use anything... just trial fit and
grind... the big thing is to have the right tools...
I have multiple different grinding machines so I can
make clean joints
Re: Pipemaster [Re: MR_P_BODY] #1098431
10/21/11 04:33 PM
10/21/11 04:33 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Save your cash for header bends and flanges.
I used two hose clamps and some scrap alum. It works nice. Gives you a nice window to weld before you unclamp and finish weld. Two strips of alum. one on each side of the pipe.
I made up four sets so I could fab a hole pipe then move to the next.
Re: Pipemaster [Re: FastmOp] #1098432
10/21/11 05:40 PM
10/21/11 05:40 PM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
Dave...you just keep on coming up with some awesome ideas...
