installing new e brake cables and having a problem.
#1098322
10/20/11 09:29 PM
10/20/11 09:29 PM
Posts: 8,526 Tenn.
jrwoodjoe
Tenn.
Installing new e brake cables on my 70 Challenger. It has the one cable coming from the pedal and then the 2 cables for the rear. Problem I am having is that the front cable seems too short and will not join up with the the balance bracket to allow me to thread on the nuts. The distance from the threaded part of the front cable to the balance bracket for the rear is about 1 1/2". I made sure that the pedal is not engaged, am I missing something? Joe
65 Barracuda 70 Challenger
Re: installing new e brake cables and having a problem.
[Re: jrwoodjoe]
#1098323
10/20/11 11:51 PM
10/20/11 11:51 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
Brakes are all assembled or just the cables through the backing plates? Cause when the cables are hanging free the springs will pull more cable out than will be pulled out with the brakes assembled...
[Re: 1_WILD_RT]
#1098324
10/21/11 01:36 AM
10/21/11 01:36 AM
Posts: 183 Eden, Texas
Strawdawg
Eden, Texas
assuming you are talking about the cable from the pedal, did you lay it beside the old one to compare the lengths?
Steve
[Re: Strawdawg]
#1098326
10/21/11 07:47 AM
10/21/11 07:47 AM
Posts: 8,526 Tenn.
jrwoodjoe
Tenn.
I usually do measure things and recall checking the lengths prior to installation. If I am not "missing something" then I guess I will have to pull and double check them. It's been several months since I routed everything but was just getting back to finishing it up.
