95 Ram 3500 4wd not working #1098218
10/20/11 05:45 PM
10/20/11 05:45 PM
Ct
gts1 Offline OP
gts1  Offline OP
Ct
Anyone have any ideas where to start 95 Ram 3500 cummins auto trans.The lever moves into 4wheel high & lo but the indicator light doesn't come on & its not in 4wd Worked fine last winter.
Re: 95 Ram 3500 4wd not working [Re: gts1] #1098219
10/20/11 06:00 PM
10/20/11 06:00 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Vacuum leak?
Re: 95 Ram 3500 4wd not working [Re: gts1] #1098220
10/20/11 06:59 PM
10/20/11 06:59 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
That's what I'd check for, including the steel lines and plastic and rubber connectors etc. Think they have some steel lines here and there that rust like the brake lines.
Re: 95 Ram 3500 4wd not working [Re: buildanother] #1098221
10/21/11 01:07 AM
10/21/11 01:07 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Yes 2 steel lines that run along the pass side frame rail from the trans X member tothe font axle.
Take a close look at the rubber connectors that go from the steel lines tothe plastic lines , if they are soaked from a trans or oil leak they can swell and lose their seal .
Re: 95 Ram 3500 4wd not working [Re: gts1] #1098222
10/21/11 09:19 AM
10/21/11 09:19 AM
PORT ALBERNI , BC., CANADA
superwrench Offline
superwrench  Offline
9 times out of 10 it's the vacuum switch on the Transfer case or the lines. I'd bet on the switch.
