Trans Temp gauge #109797
08/24/08 06:58 PM
08/24/08 06:58 PM
west palm beach, florida
modelmakerinc Offline OP
Hey guys, some of you may know of my tranny puking fliud after a short trip. I have been led to believe it may be a slipping converter and overheating the trans.
I am going through the steps to trouble shoot the problem. I need a trans temp gauge, those who may be familiar with them, would you suggest a mechanical or electric gauge ? . pros and cons of both please.
It will be a Autometer "traditional chrome" to match my other gauges and be mounted inside the car.
Thanks in advance, henry
Exceptional Architectural, Yacht and Automotive scale models. e-mail modelmakerinc@att.net for a portfolio review. www.modelmakerinc.com
Re: Trans Temp gauge [Re: modelmakerinc] #109798
08/24/08 10:52 PM
08/24/08 10:52 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
mechanical is always the best way to go...
Re: Trans Temp gauge [Re: modelmakerinc] #109799
08/25/08 12:08 AM
08/25/08 12:08 AM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
Why is mechanical always better? I have an electric, it's a very easy hook up.
Maybe this will help for the pros and cons.
http://www.egauges.com/ATM_Tips.asp?TipPage=mechvselec.htm
Re: Trans Temp gauge [Re: Exit1965] #109800
08/25/08 01:50 PM
08/25/08 01:50 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I would just run a cheapie mechanical. For oil psi, electrics are good because they keep the engine oil out of the cab that way, unlike a mechanical. But temp gauges use a sealed capilliary tube, so there's really no reason to run an electric temp gauge over a mech.
Re: Trans Temp gauge [Re: modelmakerinc] #109801
08/25/08 01:54 PM
08/25/08 01:54 PM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
I run a autometer elec gauge, very east to install, just one one to a sender in the pan. my trans temps with 8" ati are 140-165f
goodluck!!!
