Ball Joint, Tie Rod Seals? #1097952
10/20/11 12:30 AM
10/20/11 12:30 AM
Mississippi
lahatte Offline OP
lahatte  Offline OP
Mississippi
Is there a source for only the seals/dirt covers for ball joints and tie rods?
Re: Ball Joint, Tie Rod Seals? [Re: lahatte] #1097953
10/20/11 12:39 AM
10/20/11 12:39 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Jim's:
http://www.jimsautoparts.com/suspension.htm
But I would keep searching for a better price.
Re: Ball Joint, Tie Rod Seals? [Re: kentj340] #1097954
10/20/11 12:40 AM
10/20/11 12:40 AM
Mississippi
lahatte Offline OP
lahatte  Offline OP
Mississippi
Jeez! Yea, $160 bucks for seals. Wow.
Re: Ball Joint, Tie Rod Seals? [Re: lahatte] #1097955
10/20/11 12:44 AM
10/20/11 12:44 AM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Re: Ball Joint, Tie Rod Seals? [Re: OzHemi] #1097956
10/20/11 12:50 AM
10/20/11 12:50 AM
Mississippi
lahatte Offline OP
lahatte  Offline OP
Mississippi
Hey, Thanks. It looks like those are for the ball joints, which is good. What did you search for to find them? I also need a tie rod cover, but I couldn't find those.
Nevermind, I found some at JEGS.
Re: Ball Joint, Tie Rod Seals? [Re: lahatte] #1097957
10/20/11 12:58 AM
10/20/11 12:58 AM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
These maybe ?
http://www.summitracing.com/parts/ENS-9-13101G/
I don't even look at Jegs...I like Summit alot better.
Re: Ball Joint, Tie Rod Seals? [Re: OzHemi] #1097958
10/20/11 01:20 AM
10/20/11 01:20 AM
Mississippi
lahatte Offline OP
lahatte  Offline OP
Mississippi
Thanks very much.
Re: Ball Joint, Tie Rod Seals? [Re: lahatte] #1097959
10/20/11 01:11 PM
10/20/11 01:11 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
I found some at O'Reilly's so I'm sure other parts stores will carry them.
Re: Ball Joint, Tie Rod Seals? [Re: stumpy] #1097960
10/20/11 01:51 PM
10/20/11 01:51 PM
New York
EF8aar Offline
EF8aar  Offline
New York
Advance Auto Parts has them as well.. These are by Dorman.
http://shop.advanceautoparts.com/1/1/603...part-13567.html
