How to remove a powersteering pump from the case? #1097492
10/19/11 12:22 PM
10/19/11 12:22 PM
NY usa
540challenger Offline OP
NY usa
My power steering pump is leaking from inbetween the case and pump.
Can i remove the pump form the case and reseal it.
Also where would i get the seals? " iam guessing they use o-rings??"
Re: How to remove a powersteering pump from the case? [Re: 540challenger] #1097493
10/19/11 12:25 PM
10/19/11 12:25 PM
the house on the left.
cogen80 Offline
cogen80  Offline
should be just an o-ring. there are two bolts on the back that you take out and it just pulls apart. the stud looking things are actually bolts. this is on a saginaw style.
Re: How to remove a powersteering pump from the case? [Re: cogen80] #1097494
10/19/11 12:39 PM
10/19/11 12:39 PM
NY usa
NY usa
Thank you,
You wouldn't now what size o-rings by any chance???
Re: How to remove a powersteering pump from the case? [Re: 540challenger] #1097495
10/19/11 04:08 PM
10/19/11 04:08 PM
cogen80 Offline
cogen80  Offline
no idea. its got to be at least 3". probably some odd ball size though.. lol
Re: How to remove a powersteering pump from the case? [Re: 540challenger] #1097496
10/20/11 01:23 PM
10/20/11 01:23 PM
West Palm Beach, Florida
Rockland71GTX Offline
P/S pump seal kits start @ $6.46 at Rockauto
Re: How to remove a powersteering pump from the case? [Re: Rockland71GTX] #1097497
10/20/11 02:08 PM
10/20/11 02:08 PM
NORTHERN VA
THESHAKERPROJECT Offline
NORTHERN VA
Dont pry out the pump from the case. Just loosen the two studs a few turns and tap on the studs with a rubber mallot. Any auto parts store will have the seal kit for a saganaw pump.
