Cylinder head question: #1097482
10/19/11 12:12 PM
10/19/11 12:12 PM
Minnesota
MTSI Offline OP
super street
MTSI  Offline OP
super street
Minnesota
Where are the critical indentifying numbers on 440 cylinder heads?
More parts from a hoarding Uncle's garage.
thanks
Re: Cylinder head question: [Re: MTSI] #1097483
10/19/11 12:18 PM
10/19/11 12:18 PM
n.e. pa.
65rbdodge Offline
65rbdodge  Offline
n.e. pa.
there are no 440 specific heads, a big block head was a big block head. be it 383, 400, 440, ect. the numbers will be on runners under the rocker arms/shafts.
Re: Cylinder head question: [Re: MTSI] #1097484
10/19/11 12:23 PM
10/19/11 12:23 PM
dogdays Offline
dogdays  Offline
On the top under the valve cover area there will be a casting number. We usually identify them by the last three digits, such as "906" or "452".
The bad news is that most B/RB heads are functionally the same, unless you happen across a set of Max Wedge heads. Get a list of the casting numbers put together and then find a list online or come back here.
Where in Minnesota is this cache located?
R.
Re: Cylinder head question: [Re: dogdays] #1097485
10/19/11 12:26 PM
10/19/11 12:26 PM
NY usa
540challenger Offline
NY usa
R.
Don't forget the 915 closed chamber is also some what rare and desired.
Re: Cylinder head question: [Re: 540challenger] #1097486
10/19/11 01:15 PM
10/19/11 01:15 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Yeah somewhat desired these days. Lesser now because of the availability of aftermarket heads vs the cost of having a set of iron heads redone. But you're still going to be able to sell them, maybe not for huge cash but better than sitting.
Re: Cylinder head question: [Re: dogdays] #1097487
10/20/11 11:58 AM
10/20/11 11:58 AM
Minnesota
MTSI Offline OP
super street
MTSI  Offline OP
super street
Minnesota
Thanks. Some in Anoka and some up North in Sandstone.
