tremec tko, what fluid can I use? #109732
08/24/08 05:18 PM
08/24/08 05:18 PM
Oakley CA
69charger440_6pa Offline OP
Oakley CA
Hi, what fluid are you guys running in your tremecs? My manual calls for synchro mesh fluid but I cannot find the stuff anywhare
1969 Charger R/T under construction
2014 Ram 3500 Cummins
2006 Corvette Z06
2015 Corvette Z06
2014 BMW M5
Re: tremec tko, what fluid can I use? [Re: 69charger440_6pa] #109733
08/24/08 07:02 PM
08/24/08 07:02 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Ryan,......If you can't find it in your local parts stores,...I know CA is tough getting stuff off the local part store shelf,...have you tried your friendly GM dealer, or Corvette specialty shops......all else fails, have Keisler send you some,....don't sub anything else,.....you'll void any warranty you have, if you have problems
Re: tremec tko, what fluid can I use? [Re: 69charger440_6pa] #109734
08/24/08 07:07 PM
08/24/08 07:07 PM
Phoenix, AZ
MCTPhoenix Offline
MCTPhoenix  Offline
Phoenix, AZ
I picked it up from the local chevy dealer... think it was abot $20 a quart if I remember
Re: tremec tko, what fluid can I use? [Re: 69charger440_6pa] #109735
08/24/08 09:59 PM
08/24/08 09:59 PM
northeast ohio
mkdart Offline
mkdart  Offline
northeast ohio
Valvoline Dexron III mercon in mine. bought it at NAPA. Mike
Re: tremec tko, what fluid can I use? [Re: mkdart] #109736
08/24/08 10:59 PM
08/24/08 10:59 PM
San Jose, California
DennisH Offline
Vacation
DennisH  Offline
Vacation
Royal Purple Synchro. Shifts nice.
Re: tremec tko, what fluid can I use? [Re: DennisH ] #109737
08/24/08 11:07 PM
08/24/08 11:07 PM
IN
ahy Offline
ahy  Offline
IN
Autozone stores usually carry a small inventory of Syncromesh spec fluid - at least in my area. I believe its Penzoil brand
Re: tremec tko, what fluid can I use? [Re: ahy] #109738
08/25/08 08:31 AM
08/25/08 08:31 AM
Ansonia, CT
CJK440 Offline
CJK440  Offline
Ansonia, CT
I would stick with syncromesh, either GM or equivalent. I called about fluid and even though the tech sheet says ATF would work, thats only there as a last resort.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
Re: tremec tko, what fluid can I use? [Re: CJK440] #109739
08/25/08 10:29 AM
08/25/08 10:29 AM
Byesville, Ohio
Tomsecks Offline
Tomsecks  Offline
Byesville, Ohio
Pennzoil Syncro ~ $7 instead of the $20+ for the GM stuff.
