tremec tko, what fluid can I use?
#109732
08/24/08 05:18 PM
08/24/08 05:18 PM
Posts: 1,523 Oakley CA
69charger440_6pa
Oakley CA
Hi, what fluid are you guys running in your tremecs? My manual calls for synchro mesh fluid but I cannot find the stuff anywhare
1969 Charger R/T under construction 2014 Ram 3500 Cummins 2006 Corvette Z06 2015 Corvette Z06 2014 BMW M5
Re: tremec tko, what fluid can I use?
[Re: 69charger440_6pa]
#109733
08/24/08 07:02 PM
08/24/08 07:02 PM
Posts: 18,160 Mass
DAYCLONA
Mass
Ryan,......If you can't find it in your local parts stores,...I know CA is tough getting stuff off the local part store shelf,...have you tried your friendly GM dealer, or Corvette specialty shops......all else fails, have Keisler send you some,....don't sub anything else,.....you'll void any warranty you have, if you have problems
[Re: ahy]
#109738
08/25/08 08:31 AM
08/25/08 08:31 AM
Posts: 9,982 Ansonia, CT
CJK440
Ansonia, CT
I would stick with syncromesh, either GM or equivalent. I called about fluid and even though the tech sheet says ATF would work, thats only there as a last resort.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
