World Block--which roller lifter w/o grinding?? #1097160
10/18/11 06:42 PM
10/18/11 06:42 PM
Anonymous OP
Anonymous OP
Which solid roller lifter will work with no grinding on the block?? Will the Morrel do it? I am told the 829-16 Comp will work but I know from much past experience they are JUNK--I have had them with as much as 1 1/2 thou taper in the lifter body and the axle bearings are no better than the ones in boat trailers
Who has used what in the newest version Mopar Perf World wedge block Thanks!!!!!!!!
Re: World Block--which roller lifter w/o grinding?? [Re: ] #1097161
10/18/11 07:27 PM
10/18/11 07:27 PM
AndyF Offline
AndyF  Offline
Crane Ultr-Pro lifters should work. 66550-16 is the regular height lifter and it should fit. There is also a taller lifter, 66554-16 which was designed for the original Mega blocks.
