Quick Disconnect Starter Wiring #1096918
10/18/11 01:54 PM
10/18/11 01:54 PM
Dyno1 Offline OP
Dyno1  Offline OP
Does anyone offer a quick disconnect wiring setup for a Mopar (Powermaster) starter on a hemi/RB block. I spend more time and hassle trying to connect the starter wiring and cable than I should. Plus the cable is almost touching the side of the block, I would hate to have it come loose and ground against the block or frame. Thanks, Dyno
Re: Quick Disconnect Starter Wiring [Re: Dyno1] #1096919
10/18/11 04:00 PM
10/18/11 04:00 PM
renton , washington
P
perfmachst Offline
perfmachst  Offline
P
renton , washington
hi, I used one from a 950 scoop loader, catipeller. its big and carries the load, has shrouded ends that plug together. makes started work lot easier!! just food for thought.
Re: Quick Disconnect Starter Wiring [Re: perfmachst] #1096920
10/18/11 05:18 PM
10/18/11 05:18 PM
Anderson, IN
1969RR Offline
1969RR  Offline
Anderson, IN
Doing the exact same thing on mine. I was just thinking how I could put a quick connect on it. Where can I get the connector you are talking about? Thanks and sorry to hijack this! Jeff
Re: Quick Disconnect Starter Wiring [Re: perfmachst] #1096921
10/19/11 01:11 PM
10/19/11 01:11 PM
Dyno1 Offline OP
Dyno1  Offline OP
Would you happen to know the Caterpillar part number? thanks, Dan
Re: Quick Disconnect Starter Wiring [Re: Dyno1] #1096922
10/19/11 06:48 PM
10/19/11 06:48 PM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
I too tired quickly with tring to get the wires off of the starter, but I went in a different direction than your plan. I have the batteries in the trunk and the main hot cable runs from the battery to the firewall connection (a insulated bulkhead "stud type" connector) and made a short cable to go to the starter from there. I also have a small (10 ga) wire to the starter solinod from the starter relay and used heat shrink tubing to make them as one. now when I remove the starter, I disconnect the wires from the firewall and take the starter and wires out together. The ground cable from the battery goes directly to the starter mounting stud with a 90* lug so it stays away from the headers.
Just a different way to do the same thing.
Brian Dunnigan
Re: Quick Disconnect Starter Wiring [Re: '72CudaRacer] #1096923
10/19/11 07:44 PM
10/19/11 07:44 PM
MI
68shifter Offline
68shifter  Offline
MI
I use a grey quick disconnect style for tarp systems on our semis. We get them at a local napa, or fleet supplier. They are the same ones a bunch of the round round guys use. I have a year with no trouble on mine and in tarp system use they get full 12 volt loads for 20-30 seconds and hold up with no problems.
I'll try to get a pic or pn, but they are grey, about 1.5" wide and 1/2 thick 2 pole and slide together. That or try a snow plow supplier.
68' Barracuda (4 speed) 64' Savoy (4 speed) 65' Satellite (girl tranny)
Re: Quick Disconnect Starter Wiring [Re: 68shifter] #1096924
10/19/11 08:09 PM
10/19/11 08:09 PM
farmingdale ny 11735
blracing Offline
blracing  Offline
try summit #all76300 conecter.
Re: Quick Disconnect Starter Wiring [Re: 68shifter] #1096925
10/19/11 08:11 PM
10/19/11 08:11 PM
blracing Offline
blracing  Offline
or g1431 bulkhead conecter
Re: Quick Disconnect Starter Wiring [Re: Dyno1] #1096926
10/19/11 08:51 PM
10/19/11 08:51 PM
MR_P_BODY Offline
MR_P_BODY  Offline
