Guys, I had a bad power steering leak on the top of my power steering gear box on my duster, its a 1975. I took the valve body off the top of the gear box, it only had two bolts holding it on, and the o-rings were bad around the pressure line and return line, so I replaced them. I just barely snugged the valve body back on and started it up to check for leaks. No leaks now, but the car self steers all the way to the right now on its own when it is fired up. Is there a way to adjust that? It mentions in my manual something about centering the valve, but I never took the spool valve out or anything, just took the valve body itself off. Any help would be greatly appreciated.
Thanks in advance,
Will
