what is best trans cooler type #109679
08/24/08 02:45 PM
08/24/08 02:45 PM
Ohio
SteveR Offline OP
SteveR  Offline OP
Ohio
I want to install a trans cooler and see basically 2 types out there...an extruded aluminum type (frame rail mounted?) and a fin/tube type (radiator mounted).
Are there performance benefits to either or is it just a packaging preference?
My car is about 85% street / 15% track use.
Also, with either type of trans cooler, do I still use the factory "in-radiator" cooler or do I just remove the lines and cap off the nipples on the rad?
Re: what is best trans cooler type [Re: SteveR] #109680
08/24/08 03:09 PM
08/24/08 03:09 PM
Pendleton NY
terzmo Offline
terzmo  Offline
Pendleton NY
I would NOT plug off the radiator cooling section because the extra cooler is just that...extra...
Re: what is best trans cooler type [Re: SteveR] #109681
08/24/08 04:46 PM
08/24/08 04:46 PM
Chicago illinois
ChinooK440 Offline
ChinooK440  Offline
Chicago illinois
The stacked plated / "extruded" type are better than the tube and fin type .
As far as mounting goes i,ve always made some brackets out of thin flat bar and mounted them up front in front of the radiator with a 1" or so gap between the 2 or behind the front bumper where the license plate opening allows air in. The more airflow they get the better they cool.
Bulkpart.com has some nice coolers at good price$
I would still Run thru the radiator cooler first as mentioned above. That,s how all factory installed aux. coolers were installed.
