Re: Proper rear (drum) brake adjustment procedure?
[Re: MoparMarq]
#1096599
10/18/11 01:22 AM
10/18/11 01:22 AM
RapidRobert
I put the rear up on HD stands with my heaviest hyd floor jack under/just touching the bottom of the 3rd member for addt'l safety & have a helper in the dr seat start it let it idle in gear then hit/hold the brakes to stop the wheels and I spoon them a few clicks then he lets off the brake & repeat until there is a slight "tick" at one point in the wheel revolution doing each side & level driveway/HD jack stands/carefull placement of them/safety
[Re: MoparMarq]
#1096601
10/18/11 02:17 PM
10/18/11 02:17 PM
Posts: 43,228 Bend,OR USA
Cab_Burge
Back in the day before self adjusting brakes the rule was tighten the dajusteer wheil spinning the tiire until it lock up solid, back the adjuster off 5 or 6 clicks. The adjuster back then had a lot more room between the teeth so 10 or 12 clicks , if your real careful and don't move it two clicks at once, will work fine Minimum wage was $1.00 hour then, a brake adjustment was $1.50 to $3.00 depending on where you had it done, gas station(service station) versus a new car dealer
[Re: Cab_Burge]
#1096602
10/18/11 02:34 PM
10/18/11 02:34 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
my brakes have all new hardware, cables, etc. and they don't stay adjusted. being a stick truck, I suppose my driving technique might be to blame. to make them "self adjust" I think you need to be rolling in reverse, and step on the pedal hard enough for the drums to grab, which "clicks" on the adjuster. it's not really "self adjusting" it's just "slowly expanding" the shoes...so I suppose in theory, you could do this to the point of locking up the back completely? the way I do mine is at an oil change/tire rotation, while the wheel is off, remove the drum. feel for resistance. give it a few clicks, slide the drum on, if you can't feel the shoes while sliding the drum on, then it's not tight enough yet. do this until it's snug while sliding the drum on, but not so tight that you're pounding it on with a hammer. this also only works if your drums are in good shape, and don't have a lip worn into them by the shoes, otherwise you won't be able to remove the drums with the shoes adjusted as the lining will catch on the lip.
**Photobucket sucks**
[Re: 1_WILD_RT]
#1096604
10/18/11 02:43 PM
10/18/11 02:43 PM
moparpollack
Lil Herman
Lil Herman
85086
Was there ever a measuring tool for adjusting the brakes out to the drum diameter and then adjust the brakes after that?
[Re: 1_WILD_RT]
#1096606
10/18/11 02:56 PM
10/18/11 02:56 PM
Posts: 21,832 Kirkland, Washington
Pacnorthcuda
The intent of that tool was to get you close without lifting the drum a dozen times... The explanation by Cab above is the right way to do it...
Its also important to step on the brakes so that the shoes center on the backing plate and against the drum! Then adjust while spinning the drum. Very important. They are not in their working positions until you do this.
Also importnat to make sure BOTH drums are on the axles before stepping on the brake! DAMHIK!
