holley problems #1096532
10/17/11 08:18 PM
10/17/11 08:18 PM
california u.s.a.
racecar43 Offline OP
california u.s.a.
I had my 700 double Pumper built by a professional Carb Guy who builds a lot of carbs for racers the problem is that when the car gets to over 190 degrees it wont idle and you shut it off it boils over hard start like its flooded he's changed needle and seats ..any help
Re: holley problems [Re: racecar43] #1096533
10/17/11 08:24 PM
10/17/11 08:24 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
put a thicker gasket or spacer (not metal) under the carb
block of the cross overs..
I am truckless..
Re: holley problems [Re: racecar43] #1096534
10/17/11 08:54 PM
10/17/11 08:54 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
spacer and check your float levels.
Coming soon!!!!
Re: holley problems [Re: 340SHORTY] #1096535
10/17/11 09:02 PM
10/17/11 09:02 PM
I'm hoping you're not running E10 (gasahol) assuming you have a choice out there. I wouldn't want to go lower than a 180 stat unless it'a quarter miler (then a 160) but why is it running so hot?
Re: holley problems [Re: racecar43] #1096536
10/17/11 09:05 PM
10/17/11 09:05 PM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
The thicker the heat insulator spacer between the carb and intake, the better. Also, the lower the float level that you can use will lessen the chance of the fuel boiling over and coming thru the boosters while the motor is cooling down.
Re: holley problems [Re: racecar43] #1096537
10/17/11 09:18 PM
10/17/11 09:18 PM
Witness Protection Program
Kudakidd Offline
Kudakidd  Offline
as mentioned. go w/ a phenolic resin spacer and check the float levels on LEVEL ground.
Re: holley problems [Re: Kudakidd] #1096538
10/18/11 01:02 AM
10/18/11 01:02 AM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
Spacer-spacer-spacer, This is more often a summer problem or when it gets above say 80*, It normally happens after shutdown & it sits a few minutes, Its a cronic problem with mech. fuel pumps, they tend to hold pressure against the seats after you shut off (and running if the carb gets too hot also), The heat from the intake transfers & starts boiling the fuel, then its blows past the seats & flushes the rings clean
An engine will increase a good 20-25* after shut down & when the coolant stops flowing the heat goes up. Get it fixed soon, your engine will thank you for it. All you really need is a 1/2" Phonolic spacer.
75 Duster, 451 10.87 @ 123.58 NA 97 Z28 6sp., 12.01 @ 115 on a 100 shot 71 Swinger. 360 magnum. 12.58 @ 105 78 cutlass, 469 BBC. 12.70 @ 108 on street tires. http://www.youtube.com/watch?v=Z2kqNmMfheU
