brake bleed question #109542
08/24/08 09:41 AM
08/24/08 09:41 AM
Ashburn, Virginia
ashburnmike Offline OP
Ashburn, Virginia
this may sound elementary, but what is the recommended way or best way to bleed the brakes on my '70 A body.
Disc up front, drum out back
thanks again for the guidence
Mike
Re: brake bleed question [Re: ashburnmike] #109543
08/24/08 09:46 AM
08/24/08 09:46 AM
new berlin wisconsin
Mr T2U Offline
Mr T2U  Offline
start with the wheel farthest from the master, right rear. then left rear. then right front then left front.
perception is 90% of reality
Re: brake bleed question [Re: Mr T2U] #109544
08/24/08 10:06 AM
08/24/08 10:06 AM
VA
DAMOPARS Offline
DAMOPARS  Offline
VA
And keep the master cylinder full.
Re: brake bleed question [Re: DAMOPARS] #109545
08/24/08 10:17 AM
08/24/08 10:17 AM
Ashburn, Virginia
Ashburn, Virginia
this is embarrassing...how exactly do you bleed brakes...I've never done it before
Re: brake bleed question [Re: ashburnmike] #109546
08/24/08 01:30 PM
08/24/08 01:30 PM
Mechanic Falls, Maine
4BBodies Offline
mopar addict
4BBodies  Offline
mopar addict
2 man is best and quickest, one pumps the break pedal up and holds the pedal down. As he is holding, the other man loosens the bleeder and air/fluid comes out. The pedal will go to the floor, make sure the guy does NOT let his foot off! Close the bleeder, and repeat. Make sure the guy pumping doesn't pump it when the bleeder is open, only when it is closed. It should only take a few times, the pedal will feel hard, and then move to the next wheel and do the same thing.
Re: brake bleed question [Re: 4BBodies] #109547
08/24/08 02:02 PM
08/24/08 02:02 PM
BDW Offline
BDW  Offline
Go to Home Depot and get some clear tubing to put on the end of the bleeder and run it to a milk carton to keep things clean. You can also tell when the bubbles stop coming.
