3rd Gen Hemi fuel rail fitting #1095023
10/15/11 06:46 PM
10/15/11 06:46 PM
Groton, MA
N
nebo Offline OP
nebo  Offline OP
N
Groton, MA
I am in the process of putting a 3rd gen hemi into my 71 Cuda. At the moment I am working on fuel system plumbing and need to connect from the fuel rail of a 5.7 Hemi originally from a Charger to an AN6 male fitting. Does anyone know of an adapter to do this and what the part number would be?
Re: 3rd Gen Hemi fuel rail fitting [Re: nebo] #1095024
10/21/11 10:12 PM
10/21/11 10:12 PM
Portland,OR
rjsjea Offline
rjsjea  Offline
Portland,OR
I got one from ModernMuscle for a 6.1. Dave Weber is the guy to talk to there
Re: 3rd Gen Hemi fuel rail fitting [Re: rjsjea] #1095025
10/22/11 08:50 AM
10/22/11 08:50 AM
Mrytle Beach SC
johnscudashop Offline
Mrytle Beach SC
I just used a 6 AN line compression fitting , Nothing special. http://www.ebay.com/itm/330376365766?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649
Re: 3rd Gen Hemi fuel rail fitting [Re: nebo] #1095026
11/01/11 06:05 PM
11/01/11 06:05 PM
Groton, MA
N
nebo Offline OP
nebo  Offline OP
N
Groton, MA
I did a little research and found out the answer to my own question. The 3rd gen hemi uses the same style fuel rail fitting as the GM LS1, LT1 etc. engines which is described as a 3/8 female spring lock fitting for the mating connector. I used Russell 640850 which gave me a 6AN male connection. Hope this helps others that are doing the same thing.
