wheel codes on 70-build sheet...need help. #1094997
10/15/11 05:58 PM
10/15/11 05:58 PM
MO
cdp Offline OP
cdp  Offline OP
MO
Codes are.
Wheel: 63
color: TX9
wheel cover: 24
1970 B-body.
What does the wheel cover look like?
Chris
Re: wheel codes on 70-build sheet...need help. [Re: cdp] #1094998
10/15/11 06:11 PM
10/15/11 06:11 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Bottom line, are there any W codes?
Re: wheel codes on 70-build sheet...need help. [Re: cdp] #1094999
10/16/11 02:35 AM
10/16/11 02:35 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
looks like "road wheels" w/trim ring
Re: wheel codes on 70-build sheet...need help. [Re: 6bblgt] #1095000
10/16/11 10:24 AM
10/16/11 10:24 AM
MO
cdp Offline OP
cdp  Offline OP
MO
Trying to find out. Its on a friends S-bird.
The original steel wheel is a black f70-14. We weren't sure on the factory wheels as they are gone. I have seen 1 bird with factory wheel covers, which were ugly!
Re: wheel codes on 70-build sheet...need help. [Re: cdp] #1095001
10/16/11 12:18 PM
10/16/11 12:18 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
Sorry, I wasn't clear .....
Wheel: 63 = 14x5.5 "road wheel" (MAGNUM 500)
color: TX9 = spare painted black ?????
SPARE: 16 = 14x5.5" steel wheel - painted "black"
wheel cover: 24 = trim ring part #2944 424
If F70-14 with RWL the tire code on line 2 should be T87 & wheels on line 11 should be W23
Could you get the date(s) off the wheel & the DOT code off of the tire?
