I purchased a newer set of seatbelts (1975) with the shoulder harness attached for my 1973 Duster. The shoulder harness bolts to the rear interior side panel but there is no place to bolt the assembly to. Is the metal side panel different on a 1975 or is there another piece I need to bolt into the open area to attach the belt to. Hope someone can help. Thanks, Gerry
