383 TTI Headers #1094627
10/14/11 10:12 PM
10/14/11 10:12 PM
NY
Beep Beep Offline OP
NY
With a stock 383 build with stealth heads, dp4b intake, and cam. Will a set of TTI headers be worth the extra money ($900) or should I stick to the stock manifolds. Will they make more power compared to the manifolds?
Re: 383 TTI Headers [Re: Beep Beep] #1094628
10/14/11 10:42 PM
10/14/11 10:42 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
why would you spend that kind of cash on a set of headers? I'd do headers but NOT tti. Headers will help no doubt.
Coming soon!!!!
Re: 383 TTI Headers [Re: Mr.Yuck] #1094629
10/14/11 10:51 PM
10/14/11 10:51 PM
NY
NY
I know they are not cheap. What will fit just as good as the TTI's? It is a 69 Roadrunner with a 4speed and power steering.
Re: 383 TTI Headers [Re: Mr.Yuck] #1094630
10/14/11 10:53 PM
10/14/11 10:53 PM
Cleveland, Ohio
northcoastmopar Offline
Cleveland, Ohio
Yep on the headers. Price out Dougs. Just realize they may start to rust within a year or two. They still fit good though (4 speed, manual steer) and were quite a bit less than TTIs.
Re: 383 TTI Headers [Re: Mr.Yuck] #1094631
10/14/11 10:55 PM
10/14/11 10:55 PM
IN
ahy Offline
ahy  Offline
IN
The power boost will depend a lot on how much cam and which cam. Some performance cams are designed for headers and wouldn't do so well with manifolds some would. If you can post more info on your cam, you may get more info.
TTI makes nice headers. I've got a 1 7/8" set on a 400 based stroker. They fit as advertised and are durable.
Re: 383 TTI Headers [Re: ahy] #1094632
10/14/11 11:12 PM
10/14/11 11:12 PM
NY
NY
I am not sure on the cam yet. My engine builder is going to decide which cam is going to work. I have read that you have to break in your cam with another pair of headers or manifolds before installing the TTI's in order for the ceramic coating not to be damaged.
Re: 383 TTI Headers [Re: Beep Beep] #1094633
10/15/11 06:42 AM
10/15/11 06:42 AM
Missouri
68KillerBee Offline
68KillerBee  Offline
Missouri
don't know how far you are from there. but as usual, i'm sure its tooo far.
https://board.moparts.org/ubbthreads/show...e=0#Post6871719
Re: 383 TTI Headers [Re: 68KillerBee] #1094634
10/15/11 10:34 AM
10/15/11 10:34 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I use 2" TTI's on my 493 and they are a great header. Paid $691. for them with just the nickel coating. I used to run Hedman 1-3/4 headers on my old 440 and they were a nice header. After 5 years they showed a little bit of rust. The Hedman is a good header and will work fine but the TTI is the best header. Ron
Re: 383 TTI Headers [Re: Beep Beep] #1094635
10/15/11 10:40 AM
10/15/11 10:40 AM
indiana
mcmopars Offline
mcmopars  Offline
indiana
are tti really that much? i only paid 6 for coated and thermal barrier for s.b.
1961 chrysler 1973 duster 1998 ram 2005magnum 2010ram
Re: 383 TTI Headers [Re: mcmopars] #1094636
10/15/11 11:07 AM
10/15/11 11:07 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
not sure about a 4 speed but I have used several sets of Summit 1 3/4" headers on b-body's and they have all fit well. I think they are they same as hedmans. I strip them then hit them w/ VHT paint and they are fine. They also have a set of coated headers for around $200+ Another good thing is you can use all of your ex mani studs...not header bolts needed.
Re: 383 TTI Headers [Re: mcmopars] #1094637
10/15/11 12:34 PM
10/15/11 12:34 PM
PORT ALBERNI , BC., CANADA
superwrench Offline
superwrench  Offline
Yep....800 and change. Still the nicest header I've ever used.
Re: 383 TTI Headers [Re: Mr.Yuck] #1094638
10/15/11 01:49 PM
10/15/11 01:49 PM
rochester,new york
P
plumebody Offline
plumebody  Offline
P
rochester,new york
* Because they're well built
* Because they fit without banging the primary tubes with a hammer
* Because Quality costs money.
Re: 383 TTI Headers [Re: plumebody] #1094639
10/15/11 11:26 PM
10/15/11 11:26 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
blah blah blah... for what he needs a set of hedmens will work fine for 1/5 the cost. go ahead and spend more money. For what TTI cost they should jump outof the box and self install
Re: 383 TTI Headers [Re: Mr.Yuck] #1094640
10/16/11 08:43 AM
10/16/11 08:43 AM
Northern OH
rapom Offline
rapom  Offline
Northern OH
The summit 1 3/4 headers won't work with PS. The Summit ceramic coated headers 1 7/8"(Patriot headers) would work and be cheaper than the elites. They are supposed to fit low deck motors the best. The Patriot uncoated headers would be cheaper yet. I picked up some tti 2" headers that were never used on craigslist two days ago for $200. There are deals out there, you just have to look or wait for them.
Re: 383 TTI Headers [Re: Mr.Yuck] #1094641
10/16/11 11:29 AM
10/16/11 11:29 AM
rochester,new york
P
plumebody Offline
plumebody  Offline
P
rochester,new york
Really???? now your telling him what HE needs??? All this from a guy who drives a charger with a camaro hood.
Re: 383 TTI Headers [Re: plumebody] #1094642
10/16/11 12:04 PM
10/16/11 12:04 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Nope just making a suggestion... If he wants to drop $600 on a set of headers that's fine. ANd they DO work w/ P.S. as you can see here. Enjoy
Re: 383 TTI Headers [Re: Mr.Yuck] #1094643
10/16/11 07:41 PM
10/16/11 07:41 PM
Northern OH
rapom Offline
rapom  Offline
Northern OH
Summit has to change their website. Their ad states that they don't work with PS.
Re: 383 TTI Headers [Re: rapom] #1094644
10/16/11 08:14 PM
10/16/11 08:14 PM
South San Francisco, Californi...
MidPenMopar Offline
Looking for fun? Keep looking
MidPenMopar  Offline
I have had them on my 383 in the roadrunner for 10 years. I paid $800 back then. I got the ones ceramic coated inside and out. Well the coating has not weathered very well at all but then the car sits outside all year long.
Anyway they are well made and worth every cent. I always buy the best i can get as the less hassels the better. They have never leaked and i am still using the same gaskets too!
Re: 383 TTI Headers [Re: rapom] #1094645
10/16/11 10:23 PM
10/16/11 10:23 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Where?
Re: 383 TTI Headers [Re: Mr.Yuck] #1094646
10/17/11 12:44 AM
10/17/11 12:44 AM
San Jose, California
DennisH Offline
Vacation
DennisH  Offline
Vacation
TTI's. Blah yourself. They are the best.
