Re: How much power can an automatic valve body handle? [Re: Hemi ragtop] #1094137
10/15/11 04:32 PM
10/15/11 04:32 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I build my own transmissions, but after this last one with all the high $$$ parts and shipping costs, it would have been easier (and about the same cost) to just buy one from John Cope. I got most of the parts from him anyhow.
The issue with the automatic forward shift valve body is it has lower line pressure than a manual valve body. I don't have a good comparison between the valve bodies only. The new engine makes 100 HP more than the old one, and I went to a manual valve body in the new transmission.
I think the valve body pressure difference may affect how much slippage there is in the clutches and bands?
This front servo kit is "trick", reduces leakage in 2nd and 3rd gear, and applys more force on the front band.
http://www.transmissioncenter.org/Sonnax_16.jpg
Re: How much power can an automatic valve body handle? [Re: Hemi ragtop] #1094138
10/15/11 05:19 PM
10/15/11 05:19 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
If I understand correctly, you can adjust the pressure at full throttle to wide open psi in the valve body. However, when you are at PART throttle, and DON'T have full pressure that seems to be the concern.
Since the power numbers being discussed only come in near WOT that's not the major concern. The problem with sky-high line pressures in full-auto valve bodies is that all of the other pressures like throttle and governor pressure go up accordingly...if the pressures are high enough, theoretrically, the trans wouldn't upshift until 10,000 rpm.
Re: How much power can an automatic valve body handle? [Re: BSB67] #1094139
10/16/11 09:10 AM
10/16/11 09:10 AM
Tennessee
Hemi ragtop Offline OP
Tennessee
Very impresive! I like the fact that the car is drivable and runs as well as it does while dispelling the "standard" thought. You DON'T have to run deep 4+ gears, you CAN make good power with 2.5" exhuast AND stock manifolds!
When I get to the exhaust shop, I will be using 2.5" exhaust and am installing Accurate's HEMI mufflers.
On TCI's racing calculator, you are making about 568 hp. I notice the shot of the engine on the dyno on your web site. I wondered about the calculation mph vs. weight. What did your engine make on the dyno?
Re: How much power can an automatic valve body handle? [Re: John_Kunkel] #1094140
10/16/11 09:17 AM
10/16/11 09:17 AM
Tennessee
Tennessee
Thanks for the insight John. If I understand correctly, you can't increase the pressure to the clutches/bands without increasing it also to the govenor etc. Therefor, you remove the govenor etc. by installing a manual valve body. Why is this not an issue with GM or Ford auto trans?
Re: How much power can an automatic valve body handle? [Re: JohnRR] #1094141
10/16/11 09:31 AM
10/16/11 09:31 AM
Tennessee
Tennessee
You ar of course correct. I DID spend a lot on the engine and WILL end up spending a lot on the trans. I chose the builder as he INSISTED he could build a reliable auto shifting trans for the application. I don't "trash" people on here lightly. I have NEVER mentioned the builders name. Especially since he offered a complete refund. He just got in over his head. I got some good advise from Cope. He said, "a lot of people THINK they are making big power who are NOT" this allows them to get by with something that you may not be able to. There is no doubt that a Cummins is building BIG torque. The fact that you can auto shift it is impressive.
Re: How much power can an automatic valve body handle? [Re: gtx6970] #1094142
10/16/11 09:36 AM
10/16/11 09:36 AM
Tennessee
Tennessee
Thanks, I am emailing you for more info.
Re: How much power can an automatic valve body handle? [Re: Hemi ragtop] #1094143
10/16/11 06:31 PM
10/16/11 06:31 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
They all work on the same principle, do you know of GM/Fords running really high line pressure with full auto VB's?
Re: How much power can an automatic valve body handle? [Re: Hemi ragtop] #1094144
10/16/11 07:03 PM
10/16/11 07:03 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
I don't know what type of hp results the TCI calculator is generating. Of course the calculator is giving an uncorrected, and probably net flywheel hp, but it still seems too high to me. The dyno corrected gross hp was less than 600.
It is best to let the weight/mph performance speak for itself, as dyno #'s vary from shop to shop.
Re: How much power can an automatic valve body handle? [Re: BSB67] #1094145
10/16/11 07:42 PM
10/16/11 07:42 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I'd guess your making around 465 HP at the rear wheels?
Re: How much power can an automatic valve body handle? [Re: 451Mopar] #1094146
10/16/11 09:17 PM
10/16/11 09:17 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
Not sure what the hypes about, Built mine 10 seasons ago and it worked as good on the first run as it did on the last. Thats roughly 120-150 passes a year. Tf-2 and all the regular upgrades, no special equipment. Ran 10s on juice, 5500 stall, never changed.
You could; modify the governor(I did), adjust the line pressure with a guage, and modify the ratios of the kickdown linkage levers.
Re: How much power can an automatic valve body handle? [Re: RemCharger] #1094147
10/16/11 09:45 PM
10/16/11 09:45 PM
Benton, IL.
DaveRS23 Online rolleyes
Special needs idiot
DaveRS23  Online Rolleyes
Special needs idiot
Benton, IL.
My Cuda dyno'd at 520RWHP and runs 103 in the 1/8. It shifts about 6,100 with the A&A governor. I have broken a piece or two over the years, but the tranny has worked well for 5 years now. And a man valve body would have not saved the broken pieces.
Lastly, on a street car, traction is so compromised that the tranny won't have to handle but a moderate amount of the real torque available.
Master, again and still
Re: How much power can an automatic valve body handle? [Re: DaveRS23] #1094148
10/16/11 10:02 PM
10/16/11 10:02 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Exactly.
Re: How much power can an automatic valve body handle? [Re: BSB67] #1094149
10/16/11 10:55 PM
10/16/11 10:55 PM
chatham, Ilinois
fox Offline
super street
fox  Offline
super street
chatham, Ilinois
Can someone explain why the diesel guys are running around with 2-3 times the torque you are making and do it everyday with no issues?
There are 47 series trans in these trucks making 600-800 hp with twice that in torque.
I'm making 450-500 with mine and it has been great for 140,000 miles. your motor won't hurt this trans!
Re: How much power can an automatic valve body handle? [Re: fox] #1094150
10/17/11 09:11 AM
10/17/11 09:11 AM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
There used to be an electronic VB that allowed changes to shift RPM's via a little control pad that you wired inside the car.
Since it controls shift RPM at the VB, could you skirt the issues w/ high line pressure at the governor? Or maybe it still used the governor? Been a long time since I even saw one listed, let alone the specs.
Re: How much power can an automatic valve body handle? [Re: SomeCarGuy] #1094151
10/17/11 05:25 PM
10/17/11 05:25 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
the newer diesel trannys have lots of good parts like extra clutches and pinions in the planataries. More clutch area increases TQ holding capabilities at any given line preasure. Get as many clutches in it as you can and eliminate the wavy snap rings and get as much line preasure as you can and it will be fine. I saw a sighn the otherday advertisiing the cummins in the trucks is now produceing 800lbs from the factory so with the right parts you are good to go.
