How much power can an automatic valve body handle? #1094117
10/14/11 07:29 AM
10/14/11 07:29 AM
Tennessee
Hemi ragtop Offline OP
Tennessee
In an earlier post, I described losing reverse in my newly built 727 while running it in on jack stands! The trans builder promised that he could build an automatic shifting 727 that would hold up behind my 600 ft.lb. torque HEMI. When he stopped by to examine the pan, he declared the trans "terminal".
I talked to two builders who are recommended on this site. Both insisted on a manual valve body.
How much power have you guys been able to push through an auto shifting 727 before failure? This will be a 99% street driven car. Full weight 66' Coronet convertable.
Re: How much power can an automatic valve body handle? [Re: Hemi ragtop] #1094118
10/14/11 09:11 AM
10/14/11 09:11 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I'd t hink it would be other parts of the trans that go 1st. 727's are very strong and can handle a ton of power if built right. I wouldn't put a stock unit behind a 650hp motor but w/ a few changes it can easily h andle those numbers. My trans was done by Performace Automatic. I re-used my Turbo Action MVB in there street/strip unit. No problems.
Coming soon!!!!
Re: How much power can an automatic valve body handle? [Re: Mr.Yuck] #1094119
10/14/11 09:23 AM
10/14/11 09:23 AM
chatham, Ilinois
fox Offline
super street
fox  Offline
super street
chatham, Ilinois
The modern version of the 727 is the 47re and 48 re in the diesel trucks.
There are many of then running daily with with more torque than you have!
mine will make over 900 ft lbs. I have 140,000 miles on this trans--47re--- and it shifts better now than when it was new.
Re: How much power can an automatic valve body handle? [Re: Hemi ragtop] #1094120
10/14/11 09:47 AM
10/14/11 09:47 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
All the valve body does is tell it 'when' to shift. It has nothing to do with how much power is going thru said trans.
High HP +/or Torque applications should require some internal modifications such as a bolt in rear sprag, better lube circuits, better clutches, etc etc.
MY advice, you can't get any better than a John Cope unit.
And this one is behind a 484" Hemi with just over 500 HP and about 550 ft lbs of torque.
Even though I know how to build transmissions, but should I need somethign like this again, He'll get my call.
Re: How much power can an automatic valve body handle? [Re: gtx6970] #1094121
10/14/11 10:30 AM
10/14/11 10:30 AM
michigan woods
imfixinmopars426 Offline
michigan woods
i once owned,and worked at my trans shop here in town for 10 yrs..1982-1992..i enjoy building and tricking my 727's,even now,but if i had a serious car,and or a big hp cust. car,and wanted the best,and latest tech/parts, i would call john ,at CRT'S,and have it done right,but have him build a trans for the application,hp level/usage,ect,and not your budget. he is a great guy. mike
Re: How much power can an automatic valve body handle? [Re: gtx6970] #1094122
10/14/11 06:51 PM
10/14/11 06:51 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Correct to a point...the valve body contains the pressure regulator valve and pressure has a lot to do with the transmission's power capacity.
Re: How much power can an automatic valve body handle? [Re: gtx6970] #1094123
10/14/11 06:53 PM
10/14/11 06:53 PM
Tennessee
Tennessee
I did talk to John and I agree, he was very helpful. He did hesitate to put an auto shifting valve body in the trans due to the torque and weight.
What power level have you run with an auto shifting 727?
Re: How much power can an automatic valve body handle? [Re: Hemi ragtop] #1094124
10/14/11 06:55 PM
10/14/11 06:55 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Full automatic shift. So far so good.
Re: How much power can an automatic valve body handle? [Re: John_Kunkel] #1094125
10/14/11 07:00 PM
10/14/11 07:00 PM
Tennessee
Tennessee
What John from CRT and Rick from A & A both were concerned about, was line pressure with an auto shifting valve body at this TORQUE level.
If I understand correctly, you can adjust the pressure at full throttle to wide open psi in the valve body. However, when you are at PART throttle, and DON'T have full pressure that seems to be the concern.
So the question remains, "how much power have any of you put on an auto shifting 727 without failure"?
Re: How much power can an automatic valve body handle? [Re: BSB67] #1094126
10/14/11 07:04 PM
10/14/11 07:04 PM
Tennessee
Tennessee
Thanks so much! THAT is experiance that I have been looking for! To make 120 mph trap speed with over 4,100lb. takes a strong engine! How long have you been driving this setup with no issues? Did you buy a valve body from anyone in particular, or have your trans built by that shop?
Re: How much power can an automatic valve body handle? [Re: gtx6970] #1094127
10/14/11 07:06 PM
10/14/11 07:06 PM
Tennessee
Tennessee
Does your trans have manual or auto valve body?
Re: How much power can an automatic valve body handle? [Re: BSB67] #1094128
10/14/11 07:40 PM
10/14/11 07:40 PM
Tennessee
Tennessee
Who did your trans?
Re: How much power can an automatic valve body handle? [Re: Hemi ragtop] #1094129
10/14/11 10:39 PM
10/14/11 10:39 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
John. 2000 miles and about 30 passes at the track, and probably another 30 full throttle 1-2 shifts.
Rick did the one before and it probably had 200 passes, and 15,000 miles, but I was making less power then.
I'm not sure why part throttle pressure would matter
Re: How much power can an automatic valve body handle? [Re: Hemi ragtop] #1094130
10/15/11 02:23 AM
10/15/11 02:23 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I was running my #4,150 Charger in the High 11's with a near stock 727, and the Trans-go TF-2 shift kit in the stock valve body. When I took it apart the clutches still looked good, but the front (low) gear set was shot. The aluminum splines in the gear were cracked and some fell out when I pulled it off the output shaft. A new billet steel 4-pinion roller bearing set from Cope was $500.
I beefed up the new trans with a billet steel front drum and piston for safety and to add an additional clutch, $535. This required a beveled rear drum, so I got the billet aluminum rear drum $225. Figured may as well get the lightened sun shell, Max lug pump gears, and A&A Ultra sprag - $165 / $105 / $200.
Anyhow, by the time I got done with all the extra parts like servos, bands, Alto red eagle clutches and kolene steels, thrust washers, rear vent, deep trans pan, billet struts and ancor, 4.2:1 lever, Ultimate 9" converter, etc I have about $3,500+ into a 727 transmission.
Re: How much power can an automatic valve body handle? [Re: 451Mopar] #1094131
10/15/11 06:54 AM
10/15/11 06:54 AM
Tennessee
Tennessee
Thanks for the info. My local trans guy was pretty convincing on the Trans Go Shift kit with second option as well.
It is interesting that both Rick and John built you an auto shifter with no problem. Maybie I should have held back when they asked if I had dynoed the engine? Do I read right, did John build this last trans for you?
Re: How much power can an automatic valve body handle? [Re: BSB67] #1094132
10/15/11 07:14 AM
10/15/11 07:14 AM
Tennessee
Tennessee
Would you mind sharing some more info on your car? It looks like you set yours up with a "stock" look, as I have done. I notice the stock wheel/hubcaps. Are you running stock wheel wells? I am and they won't accept a large tire. I am running CalTracs. What suspension/tire combo did you use to get 4150 lb. to mid 11s? I am also running a 3.54 gear. I am shure that 4.10 would help your et. I am more interested in driving/enjoying my car for hours at a time on the street than seconds on the track.
Re: How much power can an automatic valve body handle? [Re: Hemi ragtop] #1094133
10/15/11 07:50 AM
10/15/11 07:50 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Suspension....a snubber and battery in the trunk. I'm probably the last guy you want suspension info from. Stock wheel wells. The car does not have a good 60 ft, but is the way I want it overall. Here is a little more info.
http://508charger.yolasite.com/
Re: How much power can an automatic valve body handle? [Re: Hemi ragtop] #1094134
10/15/11 10:46 AM
10/15/11 10:46 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
This trans has an auto shifting valve body.( cars owner has no interest in a full manual shift)
He told me it's a TF2 kit combined with a few mods of his own( he did not tell me those btw). It also has the billit planetary/gear set and drum and a bolt in rear sprag. with a PTC 3000 stall convertor( 10" I think)
Hands down one of the best shifting trans I've ever driven. Price was just under $3000 last spring.
Coupled with service after the sale has been second to none.
Re: How much power can an automatic valve body handle? [Re: Hemi ragtop] #1094135
10/15/11 11:51 AM
10/15/11 11:51 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
No, you don't want to hold back on the info you give, what happens when you smoke the trans, will you come on here and trash one of them because you withheld info?
So am I reading this correctly, the trans let go with it being run on jackstands? there was no load on the engine, the problem with the trans is the person that built it.
How much did you spend on the engine? Do not cheap out on the transmission, a basic rebuild and a shift kit is not going to survive in a hi torque application.
I have a hopped up Cummins in front of an auto shift 47RE, which is basically a 727 with an OD on it, I ... well not me some donkey trying out my new turbo to see if he wanted to buy one also... smoked the front clutch when it still had factory clutches, since rebuilt .... did it myself ... it has been fine with an auto shift VB that is modified, but I have a lot of money invested in the trans.
Re: How much power can an automatic valve body handle? [Re: JohnRR] #1094136
10/15/11 03:06 PM
10/15/11 03:06 PM
[So am I reading this correctly, the trans let go wit hit being run on jackstands ? there was no load on the engine , the problem wit hthe trans is the person that built it.
though I almost messed one up way back by shifting and not putting my foot on the brake to stop the wheels (on stands & not mentally grasping that tho the car was not moving the wheels were)
