Re: How much power can an automatic valve body handle?
[Re: Hemi ragtop]
#1094137
10/15/11 04:32 PM
10/15/11 04:32 PM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
I build my own transmissions, but after this last one with all the high $$$ parts and shipping costs, it would have been easier (and about the same cost) to just buy one from John Cope. I got most of the parts from him anyhow. The issue with the automatic forward shift valve body is it has lower line pressure than a manual valve body. I don't have a good comparison between the valve bodies only. The new engine makes 100 HP more than the old one, and I went to a manual valve body in the new transmission. I think the valve body pressure difference may affect how much slippage there is in the clutches and bands? This front servo kit is "trick", reduces leakage in 2nd and 3rd gear, and applys more force on the front band. http://www.transmissioncenter.org/Sonnax_16.jpg
[Re: Hemi ragtop]
#1094138
10/15/11 05:19 PM
10/15/11 05:19 PM
Posts: 25,858 Rio Linda, CA
John_Kunkel
Rio Linda, CA
If I understand correctly, you can adjust the pressure at full throttle to wide open psi in the valve body. However, when you are at PART throttle, and DON'T have full pressure that seems to be the concern.
Since the power numbers being discussed only come in near WOT that's not the major concern. The problem with sky-high line pressures in full-auto valve bodies is that all of the other pressures like throttle and governor pressure go up accordingly...if the pressures are high enough, theoretrically, the trans wouldn't upshift until 10,000 rpm.
[Re: BSB67]
#1094145
10/16/11 07:42 PM
10/16/11 07:42 PM
451Mopar
Aurora, Colorado
I don't know what type of hp results the TCI calculator is generating. Of course the calculator is giving an uncorrected, and probably net flywheel hp, but it still seems too high to me. The dyno corrected gross hp was less than 600.
It is best to let the weight/mph performance speak for itself, as dyno #'s vary from shop to shop.
I'd guess your making around 465 HP at the rear wheels?
[Re: RemCharger]
#1094147
10/16/11 09:45 PM
10/16/11 09:45 PM
Posts: 12,153 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
My Cuda dyno'd at 520RWHP and runs 103 in the 1/8. It shifts about 6,100 with the A&A governor. I have broken a piece or two over the years, but the tranny has worked well for 5 years now. And a man valve body would have not saved the broken pieces.
Lastly, on a street car, traction is so compromised that the tranny won't have to handle but a moderate amount of the real torque available.
Master, again and still
[Re: DaveRS23]
#1094148
10/16/11 10:02 PM
10/16/11 10:02 PM
Posts: 4,316 Prospect, PA
BSB67
Prospect, PA
Exactly.
[Re: SomeCarGuy]
#1094151
10/17/11 05:25 PM
10/17/11 05:25 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
the newer diesel trannys have lots of good parts like extra clutches and pinions in the planataries. More clutch area increases TQ holding capabilities at any given line preasure. Get as many clutches in it as you can and eliminate the wavy snap rings and get as much line preasure as you can and it will be fine. I saw a sighn the otherday advertisiing the cummins in the trucks is now produceing 800lbs from the factory so with the right parts you are good to go.
