Best wheel and tire combo for b-body Superbees? #1094003
10/13/11 11:50 PM
10/13/11 11:50 PM
Michigan, USA
ramman5600 Offline OP
Michigan, USA
Besides stock wheels, what are the best looking wheel and tire combos on the b-Body's? Also what is the widest wheels (and correct back spacing) for a stock suspension that has been lowered a little?
-C
Re: Best wheel and tire combo for b-body Superbees? [Re: ramman5600] #1094004
10/14/11 02:39 AM
10/14/11 02:39 AM
WA
P
pro451bee Offline
pro451bee  Offline
P
WA
I run 17x9 all around on mine ,5" backside or 0 offset .
Re: Best wheel and tire combo for b-body Superbees? [Re: ramman5600] #1094005
10/14/11 02:57 AM
10/14/11 02:57 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I like the cragar SS rims myself. However on a super bee, I think a set of vintage aluminum slot rims would look good too.
Re: Best wheel and tire combo for b-body Superbees? [Re: ramman5600] #1094006
10/14/11 03:51 AM
10/14/11 03:51 AM
Mt.Gilead, Ohio
OhioMopar Offline
OhioMopar  Offline
Mt.Gilead, Ohio
Pro-Stars and Auto Drags are a couple of my favorites. Also Torque Thrusts look great.
1969 Dart GTS 340
1969 Super Bee X9 N-96
1969 Coronet R/T X9 N-96
2015 Dodge Dart GT
2019 Ram 2500 Big Horn.
Looking for the original block for my Bee. The last 4 are 7449
Re: Best wheel and tire combo for b-body Superbees? [Re: OhioMopar] #1094007
10/14/11 03:58 AM
10/14/11 03:58 AM
vashon island washington
hunterstroble Offline
Torque thrust D's look fantastic! Then new 17" rocket wheels that somewhat resemble the Torque Thrust D's look great too. But you have a Super Bee, It will look great with any wheel
1969 Dodge dart 500 stroker 1973 Dodge Challenger 440
Re: Best wheel and tire combo for b-body Superbees? [Re: hunterstroble] #1094008
10/14/11 04:09 AM
10/14/11 04:09 AM
Missouri
68KillerBee Offline
68KillerBee  Offline
Missouri
235's in the front (i believe) and 15x10's in the back on 295/50/15's.
[image][/image]
Re: Best wheel and tire combo for b-body Superbees? [Re: pro451bee] #1094009
10/14/11 06:15 PM
10/14/11 06:15 PM
Michigan, USA
Michigan, USA
What size tire are you running on those 17x9 and was there a reason you went with the same size all around - most people go narrower on the fronts?
-C
Re: Best wheel and tire combo for b-body Superbees? [Re: 68KillerBee] #1094010
10/14/11 06:16 PM
10/14/11 06:16 PM
Michigan, USA
Michigan, USA
[image][/image]
Do you know that the back spacing is that works on the front and back? Looks great by the way. It is lowered at all?
-C
Re: Best wheel and tire combo for b-body Superbees? [Re: ramman5600] #1094011
10/14/11 11:12 PM
10/14/11 11:12 PM
Michigan, USA
Michigan, USA
[image][/image]
-C
Anyone running bigger than 18"?
Re: Best wheel and tire combo for b-body Superbees? [Re: ramman5600] #1094012
10/15/11 01:09 AM
10/15/11 01:09 AM
WA
P
pro451bee Offline
pro451bee  Offline
P
WA
Ive got 245 45 in front and 255 50 on back , and the ride IS NOT rough .In fact very smooth ride even with the tight springs I have . I went same size all around this time because the car tracks and handles better to me this way .I used to have 15x10 on the back and Super Bee's look cool that way too .
Re: Best wheel and tire combo for b-body Superbees? [Re: ramman5600] #1094013
10/15/11 01:18 AM
10/15/11 01:18 AM
SoCal
MuuMuu101 Offline
I got lucky at Woodward!
MuuMuu101  Offline
SoCal
[image][/image]
-C
Bigger than 18" is going to have serious low profile tires and if not may need the wheel wells modified. Honestly, I think 18" is about as large as it gets before it starts looking a little distasteful or out of place (coming from the kid who likes the restomod look). But beauty is in the eye of the beholder.
Re: Best wheel and tire combo for b-body Superbees? [Re: MuuMuu101] #1094014
10/15/11 01:28 AM
10/15/11 01:28 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Well these are 17x8 up front & 17x11 in the rear the rear tire is 29" tall so I think there is plenty of room for sidewalls...
Re: Best wheel and tire combo for b-body Superbees? [Re: ramman5600] #1094015
10/15/11 01:35 AM
10/15/11 01:35 AM
SoCal
MuuMuu101 Offline
MuuMuu101  Offline
SoCal
O, and what color is your car? Do you have a photo? That will help. I may have a few ideas on what may look cool.
Re: Best wheel and tire combo for b-body Superbees? [Re: ramman5600] #1094016
10/15/11 03:02 AM
10/15/11 03:02 AM
Coram, NY
Pool Fixer Offline
Pool Fixer  Offline
Coram, NY
staggared 18 rear/17 front works well for a B body. I'd think you could go as wide as 10 in the back and 9 in front. I run 18x9.5 rear w/5.5" backspace and 17x8 front with 4.5" backspace. I lowered my torsion bars a little and put 1" lowering blocks in the rear.
Re: Best wheel and tire combo for b-body Superbees? [Re: ramman5600] #1094017
10/15/11 06:24 AM
10/15/11 06:24 AM
Missouri
68KillerBee Offline
68KillerBee  Offline
Missouri
[image][/image]
-C
5.5 inch in the back... but is VERY close. I put a 1/8 spacer on it so it doesnt rub around hard corners or going up hill and turning....
fronts are just some old 14 inch wheels. i'm guessing 4.5 in the front. I want to replace them with some new 15's though.
Back end has air shocks
Front is stock or at least I haven't put anything special on it to lower it, it's how i got it.
Re: Best wheel and tire combo for b-body Superbees? [Re: MuuMuu101] #1094018
10/15/11 10:30 PM
10/15/11 10:30 PM
Michigan, USA
Michigan, USA
This is the car but has ralleys now.
-C
Re: Best wheel and tire combo for b-body Superbees? [Re: ramman5600] #1094019
10/15/11 10:31 PM
10/15/11 10:31 PM
Michigan, USA
Michigan, USA
Will be lowering it slightly as well.
-C
Re: Best wheel and tire combo for b-body Superbees? [Re: Pool Fixer] #1094020
10/15/11 10:32 PM
10/15/11 10:32 PM
Michigan, USA
Michigan, USA
What are the tire sizes? Do you have a full side view?
Re: Best wheel and tire combo for b-body Superbees? [Re: ramman5600] #1094021
10/15/11 11:47 PM
10/15/11 11:47 PM
Coram, NY
Pool Fixer Offline
Pool Fixer  Offline
Coram, NY
295/45 rear, 245/45 front
Re: Best wheel and tire combo for b-body Superbees? [Re: Pool Fixer] #1094022
10/15/11 11:49 PM
10/15/11 11:49 PM
Coram, NY
Pool Fixer Offline
Pool Fixer  Offline
Coram, NY
3/4 view too
