72 340 Duster rear tires rub springs-what gives?? #1093936
10/13/11 10:26 PM
10/13/11 10:26 PM
Canuckville
68Cbarge Offline OP
68Cbarge  Offline OP
Canuckville
A customer upgraded from factory 14 inch big bolt pattern Ralleyes in the rear to 15X8 Ralleye repops he supplied and ordered from Summit.#56-5812042
He got the backspacing of 4.5".
In theory and on paper this should have worked on this car.
I sold him 2556015 Mickey Thompson's to help fill out the rear wheel well.
Not knowing the car's history or any other modifications,it is hard to say what else has been monkeyed with.
Don't get me wrong,this car is really nice and is a strong runner.
The car was upgraded by a previous owner with disc brakes up front and an unknown 8-1/4 rear axle.
Big bolt pattern all the way around.
At this point,I am only trusting the customer's judgement-it is his car after all and he bought it restored.
Even with the 255's the dang tires rub the leaf springs.
What gives??
Too much backspacing??
15X8 was ordered with the intent to go bigger in tire sizes or go slicks in the future.
I plan on measuring the axle width flange to flange and do a proper backspacing measurement with the wheels off.
I am also going to test fit some mounted cop wheels and Centerlines with 2756015 on them as well.
Ya think that after owning and driving the car for 6 years he would KNOW HIS CAR and HE SUPPLIED THE RIMS.
I really do not want to eat the damaged tires because of this and the measuring hopefully will save grace for me and my shop.
I feel bad about since he trusted my recommendations,plus the owner is a nice guy.
Neither he or anybody else can determine if the rear is a correct A body or a Dakota rear diff until I get the car back in the shop for a closer look.
I had seen many other Dusters with fatter tires and wide rims to a certain extent where no spring relocation or mini tubs were not needed--yet,LOL.
I have been around Mopars almost all my life and this has got me stumped.I never seen such a moderate size tire do that before.
Any help is greatly appreciated.
Thanks in advance.
'68 Newport Custom Barge on a Budget!! BOAB
1973 Satellite WAGON! 318- 3 on the tree!!
2008 Chrysler 300c HEMI!
Re: 72 340 Duster rear tires rub springs-what gives?? [Re: 68Cbarge] #1093937
10/13/11 10:54 PM
10/13/11 10:54 PM
florida
74fldart Offline
74fldart  Offline
florida
yes something doesnt sound right with the total width of the rear end.
im running a 74 dart which is stock width of 52 5/8 " and i run 255/60/15 on a 4" back space and i have 1.5 " between the tire and the leaf spring .
Re: 72 340 Duster rear tires rub springs-what gives?? [Re: 74fldart] #1093938
10/13/11 11:09 PM
10/13/11 11:09 PM
Canuckville
68Cbarge Offline OP
68Cbarge  Offline OP
Canuckville
Thanks.
I wrote down the stock width you mentioned.
Are your rims 15X7 or 15X8??
Re: 72 340 Duster rear tires rub springs-what gives?? [Re: 68Cbarge] #1093939
10/13/11 11:53 PM
10/13/11 11:53 PM
Mira Loma, CA
69B3GT Offline
69B3GT  Offline
Mira Loma, CA
My friends duster has a stock width 8.75, springs NOT moved and stock tubs....cop car steels with 275 tires fit...
Re: 72 340 Duster rear tires rub springs-what gives?? [Re: 69B3GT] #1093940
10/14/11 02:19 AM
10/14/11 02:19 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
I had 15x8 chrome modular rims and 255 60 15 with no problems. I think the backspace was 3.5 or 4".
OT,, a side note do you have good prices on MT tires?
I am truckless..
Re: 72 340 Duster rear tires rub springs-what gives?? [Re: 340SHORTY] #1093941
10/14/11 07:00 AM
10/14/11 07:00 AM
crlush Offline
crlush  Offline
With 255 they shouldn't rub leafs, the rear is narrower than it should be if it were stock, he should have checked clearance there before driving car because you only need 1/4 inch clearance there, is he Shure its not rubbing the inner wheelwell? Even if you have more than 1/2 inch clearance with worn springs or bushings it will rub there.
Re: 72 340 Duster rear tires rub springs-what gives?? [Re: crlush] #1093942
10/14/11 11:27 AM
10/14/11 11:27 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
In my experience this combo is the biggest that could be fit PERFECTLY on a 71 Demon with no spring or body modifications. Enough clearance for the tires inboard and outboard with room for growth and side wall flex, no rubbing anywhere.
Mickey Thompson 255 60R15 ET Street Drag Radials 27.00 dia.
Summit Racing 15 x 8 SBP Wheel (4.250 back spacing is the key) Code WVI-61-5754044
205 75R 14 on the front, also 27.00 dia
The cars stance with this combo is right on the money as well.
Re: 72 340 Duster rear tires rub springs-what gives?? [Re: 68Cbarge] #1093943
10/14/11 04:04 PM
10/14/11 04:04 PM
oklahoma
forphorty Online content
forphorty  Online Content
oklahoma
72 Duster here. Stock spring location. 8.25 out of 75 Dart. 15x8 Wheel Vintiques ralleys. 4.5 BS. 275/60s. Tires are very close to the springs and rub during sharp turns. A 4.25 BS would probably be ideal for my car but i don't think that offset is available in a 15x8 ralley. Did you bolt the wheels and tires on the car or did the customer take them home and put them on himself?
Re: 72 340 Duster rear tires rub springs-what gives?? [Re: forphorty] #1093944
10/14/11 04:13 PM
10/14/11 04:13 PM
petaluma,ca. u.s.a.
west Offline
west  Offline
petaluma,ca. u.s.a.
measure twice,buy expensive non returnable parts once.
Re: 72 340 Duster rear tires rub springs-what gives?? [Re: west] #1093945
10/14/11 08:28 PM
10/14/11 08:28 PM
Alberta
3
340duster1 Offline
340duster1  Offline
Alberta
This doesn't surprise me that they hit. I have a 74 duster with an 8.25" rear end in it. I am running 25560R15s on 15x7 chrysler imperial rims that have 4.5" offset. The tires hit the leaf springs. I have to run 1/4" spacers to make it work. I don't like the spacers but am am looking for other options. On my 1970 340 duster with an 8.75" rear I did the offset shackle and offset spring hanger thing from direct connection (this was years ago). Also the spring perches needed to be moved. This gave me clearance for 28" 10.5 goodyear slicks on 15x8 centerlines with 4 7/8" backspace.
Re: 72 340 Duster rear tires rub springs-what gives?? [Re: west] #1093946
10/14/11 08:53 PM
10/14/11 08:53 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
IIRC, the Wheel Vintiques repops were (are?) sold standard as 15x7. The 15x8's were special order and non-returnable. Hope this helps, they were throwing up the warning flag.
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: 72 340 Duster rear tires rub springs-what gives?? [Re: GO_Fish] #1093947
10/15/11 12:00 AM
10/15/11 12:00 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Yes they are, see my post and Summit number
Re: 72 340 Duster rear tires rub springs-what gives?? [Re: 68Cbarge] #1093948
10/15/11 12:34 AM
10/15/11 12:34 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
5 x 4 1/2" bolt pattern A-body rears are much narrower than the earlier 5 x 4" pattern units.
Re: 72 340 Duster rear tires rub springs-what gives?? [Re: ScottSmith_Harms] #1093949
10/15/11 01:29 AM
10/15/11 01:29 AM
oklahoma
oklahoma
The wheel you link to is a 15x 7. A 7 inch rim would have worked okay with my 275/60s but i prefer the 8 inch. The tire rubbing is not really an issue for me as i plan to build an 8.75 rear to replace the 8.25. When i have my C body 8.75 housing narrowed, i'll just have it left slighty wider than stock A body width.
Re: 72 340 Duster rear tires rub springs-what gives?? [Re: forphorty] #1093950
10/15/11 12:04 PM
10/15/11 12:04 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I ran 275/60R 15s (Firestone Indy 500s) on 15x8s on a '74 Duster, need 4.25BS as Scott says. Quick fix is .250 spacers IF there's enough lugnut engagement and you're stuck with 4.5BS. With these 275s, I did have to space the ft spring brackets back 1/4". The car had its original rearend, springs, & ride height.
Re: 72 340 Duster rear tires rub springs-what gives?? [Re: topside] #1093951
10/15/11 04:21 PM
10/15/11 04:21 PM
Canuckville
68Cbarge Offline OP
68Cbarge  Offline OP
Canuckville
Thanks to all for the info and opinions.
Loading up the waygun tomorrow with a selction of tires,rims,a yard stick sand measuring tape.
Gonna get to the bottom of this.
Cheers.
Re: 72 340 Duster rear tires rub springs-what gives?? [Re: 340SHORTY] #1093952
10/15/11 04:22 PM
10/15/11 04:22 PM
Canuckville
68Cbarge Offline OP
68Cbarge  Offline OP
Canuckville
Yes,I do.But the miles between us kinda cancels that out.
Cheers.
Re: 72 340 Duster rear tires rub springs-what gives?? [Re: forphorty] #1093953
10/15/11 04:29 PM
10/15/11 04:29 PM
Canuckville
68Cbarge Offline OP
68Cbarge  Offline OP
Canuckville
He supplied the wheels.my tech mounted,balanced,and installed the wheels and tires.
I work at the front counter and shoulda checked the clearance before rolling it out.I drove it around the shop to the front door and did not hear or feel anything.
