2001 dodge ram 5.9 TC? weights or no? #1093924
10/13/11 09:47 PM
10/13/11 09:47 PM
Alton, IL
Dakota_Don Offline OP
Alton, IL
on a 2001 dodge ram 4x4 with a 360, does it have the weighted convertor like to older ones, or is it ballanced thu the flex plate?
The part number for the TC i have is C94 90 degree with no weights..
and i sent the core back with out looking at it.. grrr
also the flexplace is large in dia like the TC.. it has weights on it.
THANKS
Re: 2001 dodge ram 5.9 TC? weights or no? [Re: Dakota_Don] #1093925
10/13/11 09:51 PM
10/13/11 09:51 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
the weights are on the flexplate if I recall.
**Photobucket sucks**
Re: 2001 dodge ram 5.9 TC? weights or no? [Re: 70Cuda383] #1093926
10/13/11 10:35 PM
10/13/11 10:35 PM
Ohio
ralphie361 Offline
ralphie361  Offline
Ohio
on flex plate only as far as I've seen.
Re: 2001 dodge ram 5.9 TC? weights or no? [Re: ralphie361] #1093927
10/13/11 10:46 PM
10/13/11 10:46 PM
Andrewh Offline
Andrewh  Offline
yep, change occurs in 98 as I recall. so you are good to go.
Re: 2001 dodge ram 5.9 TC? weights or no? [Re: Andrewh] #1093928
10/14/11 11:29 AM
10/14/11 11:29 AM
Alton, IL
Alton, IL
ok ty vm..
